Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 04-26-2007, 09:26 PM
LopakaB LopakaB is offline
Send a message via AIM to LopakaB
1994 3.8L Cougar Won't Start
I am not getting any spark. I have power going into the DIC, traced the wires from the DIC to the plugs. How many amps need to go into the DIC in order to create a spark in the cylinder? I test for power at the plug and have power but no visual spark? Any help would be much appreciated... Thank you...
Old 04-26-2007, 10:31 PM
cowboy_bob cowboy_bob is offline
Re: 1994 3.8L Cougar Won't Start
which cylinder were you checking? try checking another one or check the gaps in the plugs they might be out. there may also be a break in one of the plug wires so check all the wires. I'm not sure of the specs on the current that is needed for spark. hopefully I helped you a little bit good luck
Old 05-10-2007, 11:57 PM
TS.D.RONIN TS.D.RONIN is offline
looks like we got the same problem
