I'm surfing into some of the treads with my problem and I think it is my "turn flasher" but, I just want to make sure before tearing up the dashboard of my 1997 LS Blazer 4WD.
The problem that I have is when I'm making those right turns, when I activate my right "turn signal" the right turn blinker indicator sometimes work however, sometimes it doesn't work. All fuses and rear lights are working and no burnout bulbs and the hazard lights and switch works fine as well. When I turn to the left the turn light indicator works fine, it does this only when turning right. Thanks in advance for any help. Eric |
Re: Turn Signal Problem
could be the turn signal switch in the steering column.
Is it just the blinker bulb on dash?
Does the dash light just not come on or comes on and does not blink? Double check front and rear bulbs and grounds. When the dash indicator does not work does the right front and rear bulbs come on or blink? When it does not work does it help to flip in on and a couple of time. The next time it does not work look at and check front and rear turn signal bulbs for coming on good.
Is it just the blinker bulb on dash? Yes.
When the dash indicator does not work does the right front and rear bulbs come on or blink? Yes. The next time it does not work look at and check front and rear turn signal bulbs for coming on good. I did and all of them works. Does the dash light just not come on or comes on and does not blink? Sometimes, when it comes on it does blink. Note, only the right blinker. |
I have the same issue with my right blinker, except my blinker will randomly start working again..........
92 S10 Blazer Sport 4.3l Vortec V6 (W) 275,000 miles Jasper engine, Rebuilt tranny + rearend 04 Pontiac Grand Prix GT 43,000 miles |
I have the same problem: 2000 Blazer left turn signal always works but the right turn signal will work for a while then won't for a while. Lamps are all okay. When it fails the flasher runs at double-speed since it doesn't have the normal bulb load and even the dash bulb does not flash. The turn lever does not seem to be intermittent when I manipulate it.
This post is old. Best to start a new thread/post with your problem. Also your problem may be different to.
