Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 04-26-2007, 06:52 PM
JimW1999 JimW1999 is offline
Red face Oil drain plug stuck
I go out to do a quick oil change after work before the mosquitos get active and I the routine turns ugly.
The oil drain plug bolt is stuck on the pan good. I use a 6 point nada, revert to double wrenching it and only manage to round it. This is a small head 13mm to begin with. I'll probably just bring it to a shop but this is embarassing. I just got done doing the intake manifold gasket on my suburban so am not a complete novice when it comes to cars. This thing kicked my butt.
Anyone have this happen - suggestions for quick fix? An oil pan runs over $200 with a gasket so I'd rather not go that route.
Old 04-27-2007, 06:10 AM
sreilly77's Avatar
sreilly77 sreilly77 is offline
Re: Oil drain plug stuck
I had my drain plug round off on me before on my old lincoln town car that i used to have. i sprayed with plug with some PB Blaster and let it soak for awhile, then got a pair of vice grips that you can tighen up and easily applied some force to loosen up the plug. i tried my best not to round it off any more than it already was and then finally, it busted loose and i gently took it out with the vice grips. Not an easy job, but with some patience it came loose.
If you want, once you get the vice grips tightened, try sliding an old pipe over the handles of the vice grips to get some extra torque. Its not an easy job, but hopefully you will be as lucky as I was.
Sean
