Old 04-26-2007, 06:52 PM
HondaCivic4358's Avatar
HondaCivic4358 HondaCivic4358 is offline
Send a message via AIM to HondaCivic4358
Exclamation Is this fuel or electrical?!
Sometime my car will not start, or just bog out once in awhile. Usually this happens if its been sitting in the warm weather for 20+ minutes, or I have put gas in it. Luckily, it does not happen ALL the time. Usually if I try to start it, and it doesn't, it usually ends up starting after 10-20 minutes of trying. I will try, and it will turn over, but not start, from there I shut it off, wait a few minutes, and then put the key in the start position and let the electronic fuel pump do its thing, and till the car stops beeping, then i will try this until it starts. It is a huge pain. What could be going on here?
1989 Honda CRX Si
D16Z6
2.5 in Exhaust
CAI
Chikara Header
Old 04-26-2007, 06:53 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: Is this fuel or electrical?!
Almost 99% sure its your main relay.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 04-26-2007, 07:28 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
yep sounds like main relay to me
Old 04-26-2007, 09:42 PM
is this a common thing? man id be happy if thats all it is. i was thinking fuel pump, but what do i know.
1989 Honda CRX Si
D16Z6
2.5 in Exhaust
CAI
Chikara Header
Old 04-26-2007, 10:00 PM
Probably the most common thing on our cars. Don't sweat it, try resoldering it.
Old 04-26-2007, 10:14 PM
yes very common..esepcially when it gets warmer outside..if i were u juss run to local junkyard and snag one..u can use one from 90-93 tegs too
Old 04-27-2007, 01:53 PM
alright. thanks guys. what else could i snag one from? 4g4d, crx, hatch, and the 90-93 integra?
1989 Honda CRX Si
D16Z6
2.5 in Exhaust
CAI
Chikara Header
Old 04-27-2007, 02:15 PM
yeah all 4th gens..u know where the lil change holder on the left that flips down..well its kinda mounted up under that with a 10mm bolt..as for the tegs they will be more of a bitch mounted center of the steering column underneath..only thing is a 90-93 teg main relay mounts uh lil different then 4th gens so it will have to kinda hang up there..i mean atleast the car will run into u find urself the right one. g/l
Old 04-27-2007, 04:33 PM
V8killer2004 V8killer2004 is offline
yeah dude im pretty sure that it is ur fuel pump, im pretty sure it wont start because of the hummidity
Old 04-27-2007, 06:50 PM
Hybrid1990crx's Avatar
main relay. it can be a really bummer if you are on a date.
Old 04-29-2007, 02:56 PM
alright. now, i found it, but getting TO it is the bitch. any suggestions?
1989 Honda CRX Si
D16Z6
2.5 in Exhaust
CAI
Chikara Header
Old 04-29-2007, 03:01 PM
Undo a few of your dash bolts on the drivers side. Have a friend gently bend the dash upward so you can access the relay from underneath. Take a 10mm socket and bust that bitch open. I agree taking it out is a bitch, you can also unbolt the steering wheel if your head is too big.
Old 04-29-2007, 11:01 PM
I think my head is perfectly proportioned =] But yeah, I'm assuming thats what it is now 100%, because my car was kind of stalling out after I started it, and I tapped on the main relay a few times, and it started right up fine, no boggin out or anything.
1989 Honda CRX Si
D16Z6
2.5 in Exhaust
CAI
Chikara Header
Old 04-29-2007, 11:08 PM
Yeah the main relay is prone to cracking at the circuit board joints because of heat and age. If you take it out and open the cover you'll see that the joints are all cracked. You can actaully try resoldering the joints if your cheap like me and wanna save a few bones.
