Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-26-2007, 06:43 PM
speeddevil's Avatar
speeddevil speeddevil is offline
windshield wipers & pump
well today i fond out that my wipers did not work. i checked the wiper mechanism. i found 2 loose wires, and i have no idea where this two wires go at. anyone have a wiring diagram for the electrical in the wiper assy by the firewall?
(edited)
well i fixed my lil electrical problem. but i found another problem as well my washer fluid is not coming out off the nozzles i went out nd bought a brand new pump, but it still does not pump out. i have a feeling the problem is in the board. does anyone know the proper way to check if board is working correctly?
pic of board.
back end of pump
1987 Chevy Caprice LS 4.3L, 700R4 Trans.
Shaved Handles and Rear Deck.
Pearl Paint Job
Last edited by speeddevil; 04-26-2007 at 10:40 PM. Reason: fixed problem but found another
Old 04-26-2007, 10:42 PM
speeddevil's Avatar
Re: windshield wipers
can i purchase this board new if bad?, before anyone says anything all hoses are all clean not clogged
Pearl Paint Job
Old 04-26-2007, 10:56 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
That board is for the intermittent wipers, I believe.
Do me a favor. Can you take a picture of the wiper motor assembly in the car and post it here?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-27-2007, 03:49 PM
mike561 mike561 is offline
Can you hear the pump whine when you try to spray? mine doesnt work either but i can still hear the pump whine when i push the buttion.
2006 Chevy Cobalt LS
Old 04-27-2007, 07:34 PM
speeddevil's Avatar
well to the way i saw the board theres a power wire from theboard to one side of the pump, and a b+ wire (no idea what b+ stands for) that goes to the other side of the pump. ok i will. to make sure i get what you are looking for what exectly is it that your talking about?
no i can not hear the pump wine
Pearl Paint Job
Old 04-27-2007, 07:50 PM
silicon212's Avatar
Confoundingly Lucid
I want to see what the motor looks like. My guess is the board is a part of the intermittent wiper motor, but I can't be sure without looking at it.
Old 04-27-2007, 07:56 PM
speeddevil's Avatar
so basically you want a picture of the unit with everything put bck together
Pearl Paint Job
Old 04-27-2007, 09:47 PM
yeah it could be an electrical issue if the pump is new and you cant hear it.
Old 04-27-2007, 10:04 PM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
Look at that board closely with a light behind it and see if any of the soldered connections are bad or have light coming through. Also look for any broken or loose components on the board. Check for cracks on the board and the components. Could be as simple as a "cold solder joint". Ive seen many with this problem. Even if you dont see one sometimes taking a solder gun to each contact will cure the problem. Its worth the try if the board is already out and a suspect.
Old 04-28-2007, 12:34 AM
speeddevil's Avatar
here are the pics i got the wipers to work normal but yet yeah i still can get the windshield washer to work
Pearl Paint Job
