Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 04-26-2007, 05:58 PM
berettagrl berettagrl is offline
Send a message via Yahoo to berettagrl
Unhappy 88 Beretta idles high
I have just recently bought a 88 beretta i have replaced the idle air control valve the feul pump and done a tune up. The car is running rough and surges is the best way to describe what the idle does while sitting at a red light or something like that. If anyone could help i would appreciate it
Old 05-01-2007, 06:29 PM
jsgold jsgold is offline
Re: 88 Beretta idles high
Sounds like a bad vacuum leak to me, possibly other things as well if it is missing. A high idle is usually because of a stuck IAC (which you have replaced) or a broken or loose vacuum line. The line could be anywhere, need to look at all small hoses / lines. Did you clean the area well where the IAC was? They tend to carbon up badly as well and should be cleaned when servicing the IAC. Check the hoses first though, that would be my guess.
I used to be indecisive, now I am not so sure.
Old 05-22-2007, 10:16 PM
starcar starcar is offline
Have you tried to talk to an expert about this? Have them take a look at that valve.
_____________________
Shane
Mid America Motorworks - Original engine in Chevrolet Corvette Parts and Accessories by Mid America Motorworks
