Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 04-26-2007, 04:45 PM
knownothin knownothin is offline
Thumbs down emissions failure
High carbon failure on a 92 cutlass supreme. Easiest cheapest way to fix? Maybe without an expensive diagnostic test?
Old 04-26-2007, 06:27 PM
maxwedge maxwedge is offline
A990 racer
Re: emissions failure
Welcome to AF. High HC's?
Old 04-26-2007, 11:29 PM
Too much carbon monoxide making it through the converter. A new one of those is out of the question. Looking for a quicker cheaper fix to get passed the test. Heard 44k might help.
Old 04-27-2007, 08:17 AM
A990 racer
Most likely a cheap aftermarket cat replacement is going to be the only way here. Make sure the car is good and warmed up before the test, also.
Old 04-27-2007, 11:04 AM
I was afraid of that. Thanks for the help
Old 05-05-2007, 11:27 PM
95supreme's Avatar
95supreme 95supreme is offline
Change your spark plugs, air filter, fuel filter, and clean the throttle body.
Then, fill up your gas tank and put some fuel system cleaner in there.
Short of that, you'll have to change the cat.
Old 05-07-2007, 12:43 PM
Yes sir you hit it dead on 95supreme, i had the injectors blown out too, made a huge difference. Thanks for the help guys.
