Old 04-26-2007, 03:49 PM
psh3kgtplaya88 psh3kgtplaya88 is offline
Angry lifter tick? plez help 95'3kgt..movie enclosed
http://www.badongo.com/file/2873341
I went 5k miles on my oil change. and i keep hearing ticking and knocking comming out of the valves under the cams.. i hear metal on metal, rattaling really loud. and the only time i hear it go away is when im cruising at 50 or so, down the street.. A few people have told me its not the lash adjuster but, im hoping it is. i hear the tip of our lash adjsuters are 1mm, and i need atleast 3mm, so this is why my cars making weird noises. however, ive heard a lifters tick, and this is a lot louder and heavier. please get back at me or ask for another video...thanks
Old 04-26-2007, 04:06 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: lifter tick? plez help 95'3kgt..movie enclosed
That doesn't sound like lifter tick to me. If it is coming from the head then it could be a collpased lifter.
Old 04-26-2007, 05:01 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
with the horrible audio, its hard to tell. but you can easily check for a collapsed lifter by pulling the valve cover.
to answer you question about the lifters (lash adjusters), they have a 1mm opening, but that design was improved upon in 1999 with a 3mm opening. they are referred to as '99 lifters' or '3rd gen lifters'. you can get a set of 24 on 3Si for about $120. do a search for the details and thread link.
also, why did you go 5k miles before changing the oil? are you running some kind of full synthetic?
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 04-26-2007, 05:24 PM
Im thinking its way more severe than a collapsed lifter. Heres another video with my jvcHDD cam, in a lot better quality, the other video was taken with my treo. Also, before all this happend i was racing an e36 m3 . I dropped my gear to L/2, to prolong my rpm range. And i've also noticed my car having difficulty shifting through gears prob becasue i went 2,000 miles over, after my oil change however, it shifts a lot better.
Sound: It sounds like a tick on steriods almost as if its a hammer hitting "metal on metal"
background: 125k miles/auto/driven a bit hard. oil filter + 4qt 5w30 w/ 1qt lucus...changed 40 miles ago..i also flushed the engine before changing the oil.
Any comments/ideas or solutions to this disaster is greatly appriciated...
thankss'
lash adjusters 3mm? rockers? valves?
http://www.badongo.com/file/2874036
Old 04-26-2007, 05:28 PM
no' i was being lazy and never got a chance to change the oil. very dumb on my part!
Old 04-27-2007, 12:16 AM
Linebckr49's Avatar
second video, much better audio quality. thanks.
the sound is definitely coming from the top end. i'm pretty sure its a collapsed lifter, there's really not much else it could be. please, pull the front valve cover. there are about 15 little bolts, if i remember correctly. you should be able to see right away what the problem is. if not, take a picture and upload it here and we'll tell you.
93 3000GT base
Old 04-27-2007, 12:26 AM
yeaa' i took off the valve cover. and i actually switched the lifters around and the noise kept comming out of the left side of the valve cover, facing the front of the car...so you still think it's the lifter? if so im ordering them in a couple of dayss' thanks a lott for the feedbackk..
pics will be up soon'
Old 04-27-2007, 08:41 PM
i actually took it to the mehcanic today and he told me he thinks the pistons are hitting the head, and to build up the motor im looking at 3k...any ideazz guyz' plez help!
Old 04-27-2007, 10:30 PM
Polygon's Avatar
The Red Baron
Yeah, stop going to that mechanic.
Old 04-28-2007, 12:47 AM
I moved the lifter around and the noise is still comming from the same location.. its gotta be a valve?
Old 04-28-2007, 04:05 AM
Linebckr49's Avatar
its very easy to check timing on the car. this woulld tell you whether or not you are are actually hitting a vavle/piston. that mechanic sounds very SHADY. consult us on AF.com fist as we know better than him what's going on with ur engine.
93 3000GT base
Old 04-29-2007, 01:53 AM
now im thinking about dropping in a new 3k motor from ebay' costing me $1,000 + to put it in!.....should i part it out? sell it as is? keep driving it till it breaks?
if i do keep the car any longer im gnna wnna do a 5spd conversion...i also dnt hav a front bumper, due to a minor accident, which insurance claimed was my fault becuase of my "faliure to yield." the bumpers is going to cost $500 painted..so i feel as if my best bet is to get rid of this thing? any advice is greatly appriciated thanks
Old 05-01-2007, 12:50 AM
Lifter tickk
http://youtube.com/watch?v=9iDDqQ7jm...related&search=
the noise my cars making "not actually my car"
http://youtube.com/watch?v=veGXwPXGFGs
still need help diagnosting the problem' any feedback is appriciated thanks
Old 05-02-2007, 07:26 PM
bump'
Old 05-02-2007, 07:42 PM
AutostradaVR4 AutostradaVR4 is offline
sounds like a spun bearing...but that wouldnt be coming from the top end. also, a mechanic should pick up on that right away.
had to tell on laptop speakers lol.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
