Old 04-26-2007, 01:52 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
Jeep Grand Cherokee Larado
I have a 1999 Jeep Grand Cher. Larado sp*. I know this is a DSM forum but you guys know stuff. The key doesnt turn in the lock cylinder. We moved the wheel, stepped on the brake, and rattled it around for an hour and nothing. I checked every fuse and everything is good. So what do you think is at fault? I am going to replace the ignition lock cylinder. is that the best thing to start on?
Old 04-26-2007, 02:03 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Jeep Grand Cherokee Larado
I've seen this before. Depending on the car, it could be the cylinder itself, or it could also be the lever that is used to create the current loop. On some vehicle, when you turn the key, a metal lever moves and completes the switch. This in turn starts the vehicle. I have seen the lever jam and keep you from being able to turn the key. I don't know how the Jeeps are put together, but either way, it sounds like you need to start pulling apart the column.
Oh, are you sure that your key isn't screwed up??? After time they start to wear and depending on how sensitive your ignition is regarding fitment, that could be a problem. Do you have a spare key you can try?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 04-26-2007, 02:15 PM
EDMUND65's Avatar
we had a spare key. the girl that has the jeep got her purse stolen and the spare was in it...
Old 04-26-2007, 02:33 PM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
try spraying some graphite down in there first... play with it for about 5 mins, if all else fails, pull it... then try and cleaning it...
When you pull it out, you should be able to see if it's worn (metal shavings/bent pieces)
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 04-26-2007, 02:44 PM
EDMUND65's Avatar
they key itself looks fine
