Dodge Grand Caracan Abs Light
Help
Have dodge grand caravan -1996 , recently changed the break pads, caliper, caliper break rubber hose, and the break line leading backwards toward the solenoid valve . After driving two days the ABS LIGHT came on and stays. any body explain the causes, and how to disconnect it . |
Re: Dodge Grand Caracan Abs Light
Could be wrong but, I'm thinking changing that line to the solenoid valve mandated using a scanner to bleed the brakes. Most components can be bled in the normal way except the master cylinder and any ABS components. They require a scanner. Not sure of the process or why, but, it's stated in a Haynes manual. There may be a diagnostic code stored that can help you pinpoint the problem. You may just have air in the ABS controller.
The ABS light indicates the ABS system is disabled. You don't have to do anything unless the light is bugging you. Just pull the fuse. You still have normal brakes but, a major safety feature of the van is no longer working for you. That said, get it fixed asap. ABS is a life saver.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
