Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-26-2007, 01:06 AM
rob67gmc's Avatar
rob67gmc rob67gmc is offline
Speedometer cable
I need to replace the speedo cable on the '89. What's the best way to get to it? I removed the front covers from the instrument panel to change the tach but can't get the speedo out.
1989 Camaro RS convertible
Engine & trans has been changed to 350 TPI w/ 6-speed manual
K&N filter
BBK 58mm Throttle Body
Richmond 3.73 gears
Spohn full length adj. torque arm
Spohn lower control arms w/ poly bushings
Spohn Adj. panhard bar w/ poly bushings
Spohn front & rear sway bars
Spohn weld-in subframe connectors
PST complete front end rebuild kit
KYB struts & shocks
Old 04-26-2007, 02:34 AM
Morley Morley is offline
Re: Speedometer cable
You need to remove the 2 nuts at the bottom of the cluster (look in the holes). Then drop the panel under the dash. Get up under there with a long screwdriver and a flashlight. There is a clip on the back of the speedo with a leg sticking up and out the side, Push that leg with the screwdriver and with a free hand pull the inst. cluster out.
Old 04-27-2007, 01:28 AM
rob67gmc's Avatar
Thanks, Morley!!!
I removed the 2 nuts at the bottom and cluster was loose but still would not come out for the steering column. I was able to tilt the cluster enough to get the cable off and a new one on.
Thanks again,
Rob
K&N filter
Richmond 3.73 gears
KYB struts & shocks
