Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Interiors
Old 04-25-2007, 08:32 PM
MazdaX's Avatar
MazdaX MazdaX is offline
Headliner project V:2.0
was grey cloth now black vinyl patern matches factory pattern..had to look long and hard for such a patern. Anywho , works well , cheap , easy and boosts some visual points for the URL XD
Not a difficult project but time consuming to smooth out the wrinkles which I still have to do.
2004 Mazda 6i
1997 Tahoe
Old 04-25-2007, 08:43 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Headliner project V:2.0
I bet if you did a thorough write-up of the process it would help people out in the future who are unsure of exactly what they need to do.
If it's good enough, you may even get a mod to sticky it...
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 04-25-2007, 08:46 PM
JScharF JScharF is offline
That looks really nice... I noticed mine is starting to peel when i was washing the windows yesterday How much money and work did it take to get in?
1995 Mitsubishi Eclipse GS
Old 04-25-2007, 10:19 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Looks like it turned out good. I still gotta finish my headliner...
Oh and we don't sticky em anymore. We add em to the Tech Article section and add it to the index list.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 04-26-2007, 10:07 AM
MazdaX's Avatar
Well I did it in such a way that it wouldn't peel later down the road.
Anywho , It costs about 8.99 a yard ,just need two yards @ 54"s wide so you have enough to work with and have a little extra incase of mistakes.
You need something like a razor knife to cut it because anything else sucks as its vinyl.
I cleaned the headliner fabric , drilled some tiny holes through the headliner piece to give it a spot for the adhesives to go instead of just in between, I used a fiber glass resin and strengthened it up about 50% , heated the vinyl up by laying it out across the cement in my parking lot under the 90 degreen sun for about an hour so it molds like clay.
Afterall of that I used a shock absorbing silicone , something with some serious sticky but could still be worked with once setup began. Lay out your stuff and try to center it or else if you make a booboo you wont have a lot left to work with and may not be able to disguise it.
Make the incisions for the sun visor, overhead lamps , sunroof if applicable XD , and press press press then leave out for about an hour. Mine looked like it have a ton of wrinkles at the begining in the first 10 minutes but today it smoothed itself out with all the stretching I did to it yesterday which makes my life much better.
When you go to remove and replace headliners..it's a pain without taking ALL the paneling pieces off that go over it so I'd suggest removing the grey panel for the 1/4 window as well or you may end up jacking up the strength or the headliner and create a weak point where it may hang.
2004 Mazda 6i
1997 Tahoe
Old 04-26-2007, 11:18 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
I did a buddy's headliner in black vinyl, if you take your time, it can turn out good as yours did. Good work homie.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
