Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-25-2007, 08:58 PM
WhiteRodeo's Avatar
WhiteRodeo WhiteRodeo is offline
Send a message via AIM to WhiteRodeo
Check Engine light on 1999 rodeo
My check engine light has been on for about a year now. I went to go to a diagnostic check on it, and the code said it was an "evap" leak, but when they tested it with smoke, no leaks were found. I replaced my gas cap, and that seemed to fix the problem temparily. About a month ago, the check engine light kept coming on and off 3 or 4 times, and now it is stuck on, with a brand new gas cap and a diagnostic check done twice on it. Any one have any idea how I can fix it? My inspection is due in a month and I got some trips to make in the summer with my truck and a trailer with my motorcycle. Thanks people.
Old 04-25-2007, 09:04 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Check Engine light on 1999 rodeo
have you ever had the intake manifold gasket replaced?
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 04-26-2007, 06:51 PM
WhiteRodeo's Avatar
That is a bit strange, I read about GM having a large recall on the intake manifold gaskets. I am going to see if i can replace that myself in my garage.
Old 04-26-2007, 06:58 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Here is lots of info on replacing the IMG (thanks to Amigo-2k's FAQ)
http://isuzufaq.ibctech.ca/#faq5
Just remember the revised torque spec is 13 ft lbs. Use an inch lb torque wrench though since at that low setting the ft lb one will be very innacurate.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 04-26-2007, 09:03 PM
WhiteRodeo's Avatar
Thanks Gizmo. I'm gonna have to pick a lb per inch torque wrench tho, I only have the large.
