Old 04-25-2007, 07:57 PM
pcabn pcabn is offline
2000 Lesabre Noise in Rear
I have a 2000 Lesabre that makes a noise in the rear when going over bumps.. cracks in pavement. It sounds like something loose maybe in suspension?? It reminds me of losing a clip on brake pads..It have been in various shops. I have had estimates from 350-2200 to fix it. But everyone says They never heard this before and might need to keep replacing parts to fix it. I dont think it is the brakes as I have stepped on them and the noise is still there. I was wondering if it could be the emergency brake since I believe that is a drum in the rotor?? When it is on a lift they cant duplicate the noise..Any thoughts I would appreciate..
Old 04-26-2007, 08:01 AM
imidazol97 imidazol97 is offline
AF -Advisor
Re: 2000 Lesabre Noise in Rear
Can you duplicate the noise by putting your weight on the back of the car to bounce it up and down?
Is it somethiing inside the trunk? The jack and equipment under/on the little spare wheel?
It could be the shock absorber mounts. That would give a solid-sounding thud effect.
It could be the bolts holding down the line for the emergency brake on top of the arm that holds the rear wheels in place. The emergency brake just uses the piston of the caliper and mechanically pushes on it; there is no drum.
Old 04-30-2007, 06:40 PM
I have removed the spare and jack that is not it. I have tried bouncing the car up and down and can't duplicate it. It sounds or feel like something with the shocks. As soon as the car starts moving you can here it. Perhaps it is a shock mount. It dosen't seem to effect the drive as far as alignment.
Old 04-13-2009, 05:39 PM
Robdaparamedic Robdaparamedic is offline
My dad and I both have "02's and he had a hell of a time when he had rear shocks replaced. The bolts that hold the shock to the lower arm were hitting the boot on the shock and making a noise. You say you can't hear this when you bounce the car up and down though ???? I replaced mine and changed those cheap pieces of crap with some real bolts/lock washers/nuts. My car also makes a wierd noise when you take off. Like a creeking old rocker, I can't figure it out and I'm not about to start changing parts at those prices. I now just turn the radio up and they seem to have gone away. Good luck.
Rob
Old 05-12-2009, 08:15 AM
pcmos pcmos is offline
Send a message via AIM to pcmos
First of all, the emergency brake on this car is NOT a drum inside the rotor. The rear emergency/park brake system makes use of the main caliper itself. The hydraulic main caliper is mechanically activated by the emergency brake cable. There is no seperate emergency brake drum like you would see on a Ford Crown Vic.
This is a good point to remember if you ever try to replace rear pads because you need a special tool to rotate and retract the piston on the rear calipers for this car. If you try to force the calipers to retract with a C-Clamp or something you will destroy the caliper.
I would strongly recommend that you take a close look at the sway bar end links and bushings. Buick uses plastic end link spacers from the factory and they tend to crack and break loose which will cause the sway bar to clunk around like crazy. Generic Polyurethane end link kits from autozone work really well as replacements and cost less than 40 bucks.
Other than that you'll want to inspect the rear toe adjustment links which look like typical tie rods welded to long steel arms. The adjustment links are purely there to adjust the rear toe setting. The ball and socket joint itself can wear out where it attaches to the knuckle or the hinge bushing can wear out where it connects to the rear subframe.
Give the exhaust system a good shake, make sure you aren't hearing something from the exhaust hangers.
Check the rubber spring insulators to look for deterioration and splitting.
Also inspect the upper shock mounts inside the trunk compartment.
Finally, make sure that your air suspension is working properly, if the air suspension is malfunctioning for any reason the car may be riding way too low. The shocks themselves have air cushions which adjust the ride height. If you put a heavy load in the trunk you should hear the air pump kick on when you first start the car, it should operate for a short time and then cut out after the ride height has reached an appropriate level. As far as I know, automatic level control was standard on both LeSabre Custom and LeSabre Limited starting in 2000. From 1992 to 1999 only LeSabres with the Gran Touring package came with air struts.
It really shouldn't be hard to narrow down a noise concern from the rear of this car. I've never had a clunk or squeak in the rear that I couldn't immediatley identify and solve. Front end noises get tricky because of the number of components involved. Fortunately this car has a really simple rear end.
Old 05-12-2009, 08:21 AM
When you say you've had this to various shopes and they couldn't identify the problem. That really surprises me because this car has a really simple configuration for its rear suspension. If you can't narrow down the problem yourself I'd strongly recommend taking it up to a dealer. They should get it solved pretty quickly. Any mechanic who knows the LeSabre well will probably pinpoint the problem almost immediately.
Old 04-20-2012, 08:18 PM
mike120 mike120 is offline
Buick Lesabre 2000 Custom. I HAD a rear noise that sounded like something was loose in the back of the car around the spare tire or there abouts. Every time I hit a pot hole or went over speed bump I would hear metal rattling. Drove me nuts! I removed everything from the trunk and even had the back of the car inspected for any loose hardware. The problem didn't go away. THEN, I had my rear breaks replaced/repaired and the noise is now GONE. The person that replaced my brakes said he also had to FIX my emergency break cable...HUMM!
Old 05-19-2012, 09:32 PM
jamyers jamyers is offline
We had the same symptoms on our 2001 LeSabre - sounded exactly like something loose rattling around back there, even with the trunk completely empty, and the shocks, exhaust, etc checked multiple times for tightness. Drove me crazy!
So with my wife driving slowly around a dirt parking lot and me hanging our the open passenger door on each side, you could clearly hear something from the right rear suspension area. I then put zip-ties around every joint or connection or close-fitting-part back there (not that many places, actually), and when the noise stopped/changed, I had it.
Ended up being the tie-rod end on one of the toe adjustment links was worn, BUT - it was ONLY worn in the position where the car rode with the auto-levelling on. Because of the auto levelling, the joint wears in one spot, but when you or a mechanic checks it, usually the engine is off and the car is sitting *slightly* lower, but just enough for the wear not to show. Grrr....
Try tying something around those joints and see if the noise changes any.
Old 06-19-2015, 07:12 AM
460dan 460dan is offline
Tie rod ends needed replacement on my 2001, but made no noises. Now, 100,000 miles later I have a distinct delayed clunk on the right side. Have done all of the obvious, clean trunk, shake exhaust, pull, tug, pry on everything I can on a lift and on the ground, found about an eighth inch play in the right outer control arm attaching bolt. Miserable place to get at, apparently if I'm to go any further with it, I would have to lower the whole suspension as an assembly. What I did yesterday with the car raised...I tried to tighten the attaching bolt through the bushing...no soap, could not do it, but what I did get for my efforts was to rotate the bolt about a quarter turn. The noise is gone. Not fixed, but problem found. I think I have a flat spot in the bolt. Would like to replace that and move on. How does one lower the suspension? Does that make any sense?
