Old 04-25-2007, 03:32 PM
mit3000gtsl mit3000gtsl is offline
misfire
hey , i recently put a used engine with about 50k and also did the 60k service with all the recommended items changed. when I start the car only 4 out of 6 cylinders fire. I checked the ignition coil but its not that , i bought a new one and put that intead of coil C but still nothing. I also checked the timming , spark plugs and spark plug cable everything is new and looks fine.
any Idea what could be the problem?
Old 04-26-2007, 07:56 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: misfire
It is somewhere in your wiring or ECU. That should be fun to hunt down. First I would pull the ecu and see if any of the capacitors are leaking.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 04-26-2007, 12:34 PM
Igovert500's Avatar
blue + red light magnet
Re: misfire
http://www.stealth316.com/2-pwrtransunit.htm
http://www.stealth316.com/2-ignitioncoils.htm
http://www.stealth316.com/2-ecmremoval.htm
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 04-26-2007, 05:31 PM
Re: misfire
thank you so much for your suggestions, I'll look it uo this weekend and hopefuly find something .......thanx again.
