Go Back   Automotive Forums Car Chat > Dodge > Avenger
Old 04-25-2007, 02:30 PM
pld pld is offline
avenger stalls out
hi all new here, just picked up a 96 avenger, runs great till it gets warmed up.
then it stumbles and misfires and shuts off. thinking some kind of sensor in the distributor maybe, anyone else run into this problem.
Old 08-14-2007, 09:56 PM
terry LAMB terry LAMB is offline
Re: avenger stalls out
I have a 96 with the same problem.If your wont start back up when hot.Unplug the fan sensor and it will run again.I am still trying to figure mine out.
Old 10-24-2007, 08:25 PM
95_dodge_avenger 95_dodge_avenger is offline
timming issue, u need a new belt
Old 12-22-2007, 01:51 AM
JuztinB JuztinB is offline
I Recently had a similar issue with my 97 avenger 2.5, it would stall out if the accellerator was pressed down to rapidly, but if gradually depressed the R.P.M.'s would climb as if there was no problem at all, well after a week at the "Mechanic's" and $465 later and they gave it back to me still scratching there heads, my dad & i decieded to take a look at the Intensity of the spark being produced by the coil, it looked normal until the throttle was opend up causing the engine to Stall/Bog out, thats when the spark was Weak, really weak, so long story short I replaced the Ignition Coil in the Distributor w/ a used one from a junk yard (the car even had a reBuilt Distributer when i bought it, even rebuilt one's can be defective!!) the problem was 100 percent solved
