Old 04-25-2007, 01:30 PM
ronald dale ronald dale is offline
Question 88 park ave.
My air cond will not blow cold air, nor will the heater blow hot air. The compressor works fine .I was told it was some kind of relay switch. could it be? Please help as summer is around the corner. Thanks in advance!
Old 04-25-2007, 07:00 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 88 park ave.
Do you have ACC (auto climate control) or, do you have manual temp & fan control?
Old 04-25-2007, 09:49 PM
Exclamation Re: 88 park ave.
I have ACC and the control works as in it will go to the temp I sellect, but does not blow cool or heat. Thanks!!
Old 04-26-2007, 04:25 AM
HotZ28's Avatar
AF Moderator Elite
Re: 88 park ave.
So, I assume that the blower motor on the firewall is not operating? Check for voltage to the blower motor on the purple wire, if none you may need to replace the blower control module located on top of the blower box, (under the fuse & relay panel) on firewall. Do a search for "Blower Control Module" for more info.
Old 04-26-2007, 06:18 AM
Re: 88 park ave.
The Blower moter appears to be working fine. Any other suggestions??
Thanks!!!
Old 04-26-2007, 04:23 PM
Can any one tell me where the heater/accontrol vac. is located on an 88 buick park ave? It has ACC . If this is the culprit, will it cause the blower to blow but have no heat or cool air? Thanks
Old 04-28-2007, 05:35 AM
deerefeed deerefeed is offline
Re: 88 park ave.
Do you have air flow out of the vents? Behind the glove box is the heater box and vacuum connections. The glove box will hang down if you move the rubber stops at the back and allow it to open all the way. You can watch the arm on top of the heater box move back and forth as you adjust the temperature up and down. That's electrically operated and it moves a flap inside the heater box blocking the heater core. The other adjustments for the location of the air (windshield, floor, dash vents) are vacuum operated. There's a vacuum connection at the heater box as well. If you don't have air flow and the blower motor is running possibly the impeller has broken or you have obstructions in the A/C evaporator coil.
Old 04-29-2007, 06:45 PM
The air does flow through the vents ,but just not hot or cold. Would you also happen to know what size gas tank it has? Thanks!
Old 04-29-2007, 08:51 PM
Re: 88 park ave.
Did you check the operation of the metal rod on top of the heater box? You can see it when you drop the glove box open all the way. If you set the heat to full the rod should move towards the passenger side and the reverse for colder. The rod has a bend on the left side that fits into a plastic clip for the heater door inside the heater box. On the right end the rod is threaded and again it fits into a plastic clip and the threads allow adjustment. Sometimes the rod can pull out of either end.
Now, assuming that door works properly you might need to verify that the A/C is in fact cooling the evaporator coil. The compressor may be working but without refrigerant, there's nothing to compress. You can take the cap off the filler valve on one of the aluminum lines next to the fire wall and momentarily press the valve to see if there is pressure. It looks like a tire valve. If there's no pressure then the refrigerant has been lost through a leak.
The gas tank I believe is 60 liters or almost 16 US Gallons.
Old 04-29-2007, 09:01 PM
Talking Re: 88 park ave.
Thanks so much. We are sure gonna check it out in the morning!! I will let you know!
Old 04-30-2007, 08:30 AM
Smile Re: 88 park ave.
You are awesome dude!!! It worked ! The rod will not move by itself so I have to do it manually. So whatever controls the auto movement of the rod has gone out. Thank you so much!!!!!!
Old 04-30-2007, 09:41 AM
Re: 88 park ave.
[quote=ronald dale]You are awesome dude!!! It worked ! The rod will not move by itself so I have to do it manually. So whatever controls the auto movement of the rod has gone out. Thank you so much!!!!!![/quot
If the coolant is low will it cause the compressor to not kick in? also, does it have a fuse or a relay switch for the a/c and do you know where it is located? Sorry for sounding so dumb, but I got this car from an elderly lady and she didn't have the book and I was very unfamiliar with this vehicle. Thanks, man!!
Old 04-30-2007, 10:10 AM
HotZ28's Avatar
AF Moderator Elite
Re: 88 park ave.
Old 04-30-2007, 08:51 PM
Re: 88 park ave.
Ronald,
If the refrigerant is low the compressor will cycle on and off and eventually the computer will shut it down so that the compressor stays off. Are you familiar with the sound of the clutch clicking on and off? Also, when the compressor comes on for A/C the cooling fan on the rad should come on at the same time. If you just want cooling you can move the air mix door manually and leave it for the summer and move it back in the winter if you need heat. Keep in mind this arrangement will not pass a safety check since you need to be able to control the temperature without reaching into the glove box from the driver's seat.
Trust me, the owner's manual wouldn't tell you this much. It tells you how to put the key in and drive. Buick wants you to bring the car back for fixing.
Nice photo HotZ28!! Is that from your teachings?
Old 05-07-2007, 06:32 PM
Thumbs up Re: 88 park ave.
Ronald,
Thanks man, I really apppreciate your help.
