Old 04-25-2007, 11:39 AM
mstngcobrasvt98's Avatar
mstngcobrasvt98 mstngcobrasvt98 is offline
Send a message via AIM to mstngcobrasvt98 Send a message via Yahoo to mstngcobrasvt98
Angry Stripping help
Im using CSC and have had the body in it for 24 hours at least and the paint is still stuck on. Whats wrong? The paint is some automotive touch-up brand. Does CSC eventually lose its power after so many uses? Thanks.
Just a good model of mine:
2 Fast 2 Furious Skyline
STOLEN!!!
Another go at it:
2 Fast 2 Furious Skyline.. Pt. 2
Old 04-25-2007, 11:40 AM
tonioseven's Avatar
Re: Stripping help
Have you tried brake fluid? In my personal experience, CSC loses some of its effectiveness after a while.
Old 04-25-2007, 12:39 PM
stevenoble's Avatar
Re: Stripping help
Use Isopropyl Alcohol.It's quick and easy and strips off every paint I've tried it on including all the popular model paints and automotive paints as well.The odd time I have used brake fluid I've found it made the plastic weak and brittle.
Steve Noble
Old 04-25-2007, 06:36 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Re: Stripping help
I agree with both posts. Brake fluid does, in fact, make the plastic brittle (in my experience) but work in a handful of hours, and if you're mindful, you can get the stuff out before the plastic is affected. It also doesn't work on resin, I understand. CSC is good for chrome and... what else?
Also, you may need a pole.
Old 04-26-2007, 02:23 AM
chato de shamrock chato de shamrock is offline
Re: Stripping help
Try using alcohol. The higer the isopropyl, the better. I had problems removing paint made by Kustom Kolors and only thing that was able to remove it was alcohol. I have some 91% isopropyl and it only removed the paint after I had the model soaking over night and then scrubbed the paint off. I noticed once the alcohol evaporated the paint would be hard to scrub off, so It took me a few days and nights of over night soaking and scrubbing. If you can find anything higher than 91%, try it.
HEY!!! HEY!!!
