Old 04-25-2007, 10:33 AM
ecnar ecnar is offline
swapping rims
Hi, I have a 99 Silverado 4x4 ext cab. I now have the factory steel 16x6.5 inch rims with 245/75/16 tires on my truck. I have a set of aluminum 16x7 inch rims from a 2002 suburban that I want to install. Will the factory lug nuts work on the aluminum rims or do they require a different lug nut. Both sets of rims have the plastic center caps that attatch to the lug nuts. I plan to put a set of 245/75/16 kumho road venture at tires on the aluminums.
Thanks,
ecnar
Old 04-25-2007, 08:14 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Re: swapping rims
They should work. I believe a fellow member, BlenderWizard, has done something similar.
He'll check in soon.
*Under Construction - New sig to debut*
Old 04-26-2007, 12:35 AM
JeRzEy SiLvErAdO's Avatar
JeRzEy SiLvErAdO JeRzEy SiLvErAdO is offline
Send a message via AIM to JeRzEy SiLvErAdO
Re: swapping rims
Thanks,
ecnar
It should work, as long as the lug nuts are rounded on the side that seats to the rims... I switched my 16x7 to 20x8.5 silverado SS rims and they bolted up right up no problems
2002 Z71 Silverado 4x4 5.3
Gibson Catback Exhaust
K&N 77series Intake with AEM Dryflow airfilter
Hypertech Programmer
Jet MAF
Aeroforce Interceptor Gauge
8500K HID's
Old 04-26-2007, 10:41 AM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: swapping rims
Bingo, check the pics. IIRC the lugs were the same, but don't quote me on that
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 05-02-2007, 01:51 PM
Re: swapping rims
It fits! (x4). Thanks for the help. I had the the rims installed with the new tires I got on Ebay. The seller had a local shop and I was able to see the tires up front before I bought them. I got Electra Ironman LT 66 tires made by Hercules tire. They have the same thread pattern as Hercules terra trac mt. They cost me $409 installed. I will try to get pics soon.
Old 05-02-2007, 08:51 PM
Re: swapping rims
Congrats man!
Glad you're happy and everything worked out in your favor.
