| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
1st Gen turbo
i was wondering what does the turbo on the 1st gen eagle talon tsi rev up to....does it rev to 5,000 or 8,000
Re: 1st Gen turbo
untill it hits the rev limiter..
DSM geek |
Re: 1st Gen turbo
... which is 7500 stock I believe.
Re: 1st Gen turbo
From re-reading the question, it looks like they are asking what rpm the turbo spins at. If so, it's possible for the turbine wheel to reach speeds in excess of 100,000rpm.
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
Re: 1st Gen turbo
Caz i Was ganna put it in a honda like on a b16a2 so i wanted to knwo if it would be good for it
Re: 1st Gen turbo
Now I'm confused. Can you try and re-phrase your question so we can help you out.
Re: 1st Gen turbo
He's putting the 14b in a honda (B16a motor) and I'm guessing he wanted to know at what rpms it maxed out at. That's my best guess.
Re: 1st Gen turbo
I'm guessing he wants to know spool time and if it will match is small motor
2004 Flame Red SRT-4 |Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd| Mods: ![]() |
Re: 1st Gen turbo
yes it will be fine for the honduh motor. i knew more than a couple of guy's that would use those. the 14b will probably blow your engine, though.
a T-25 [stock 2g turbo] is perfect for those engines. the 14b honduh guy's i knew always had problems. the T-25 guy's were always running strong... on different engines turbo's do different things. there is no way to compare a 4g63 [capable of ~400+ HP on internals] to a B16a2 [~250+ hp on stock internals w/all that aluminum ???]. the rev is all different, and isn't that a VTEC engine? not to mention the much different exhaust capabilities. and the 4g63 was designed to be a powerful engine with a turbo strapped on it from the get go... |
Re: 1st Gen turbo
like my car goes up to 8,.0000 rpm and i wanna know if the turbo will keep up to that rpm or cut out
Re: 1st Gen turbo
Yeah, that shouldnt be a problem. The 4g revs up to 7500rpm
