Go Back   Automotive Forums Car Chat > Jeep > Cherokee > FYI - How to...
Old 04-24-2007, 11:09 PM
IdahoJeeper's Avatar
IdahoJeeper IdahoJeeper is offline
Computer Codes For 91-97 XJ
Hi All!
After searching the forum far and wide and not finding the codes and meanings, I remembered they were listed at http://go.jeep-xj.info/HowtoECUcodes.htm
Here are the 91-97 codes:
11 No crank signal to computer. Fault in wiring between crankshaft position sensor (CPS) and ECM ( PCM or computer ) or faulty CPS.
12 Battery disconnected. Battery or power to the ECM disconnected in the last 50 key cycles.
13 MAP Sensor. No change in Manifold Absolute Pressure (MAP) between engine off and on. Check circuit and MAP sensor.
14 MAP Sensor. MAP sensor voltage too high or low. Check circuit and sensor.
15 Speed sensor or circuit. No signal detected from speed sensor. Check circuit and sensor.
17 Engine running too cold. Wrong or faulty thermostat. Check also sensor and circuit for fault.
21 Oxygen sensor or circuit. O2 sensor or wiring faulty.
22 Coolant sensor or circuit. Check temp sensor and wiring.
23 Intake air temp or circuit. Check air temp sensor and wiring.
24 Throttle Position Sensor (TPS) Check TPS sensor and wiring.
25 Idle Air Control circuit (IAC) Check IAC sensor and wiring.
26 Injector circuit resistance. Peak injector current has not been reached or injector circuits have resistance
27 Fuel injector control circuit. Will need specialist diagnostics.
31 Evaporative control circuit. Fault in fuel evaporative control circuit or hoses.
33 Air conditioning clutch relay. Wiring to A/C clutch fault.
34 Cruise control circuit. Fault in circuit.
35 Cooling fan relay. Check relay and circuit.
36 Air switch solenoid circuit. Air switch solenoid circuit (non-turbo) or the waste gate solenoid on turbocharged models
37 Torque converter clutch. Needs specialist or dealer diagnostics.
41 Alternator field switch. Switch not operating correctly and check charging system.
42 Automatic shutdown relay. Check relay and circuit. Needs specialist or dealer diagnostics.
43 Misfire. Misfire in one or more cylinders.
44 Battery temperature sensor. Needs specialist or dealer diagnostics.
46 Battery over voltage. Check charging system.
47 Battery under voltage. Check charging system.
51 O2 detects lean mixture. Check sensor and circuit and for vacuum leaks.
52 O2 detects rich mixture. Check fuel injection system and sensor.
53 Powertrain Control Module. PCM (ECM) fault. Needs specialist or dealer diagnostics.
54 Distributor sync pickup. Change sync sensor in distributor.
55 End of code. Trouble codes finished or none recorded.
61 BARO solenoid BARO solenoid failure
62 Emissions reminder. Emissions maintenance reminder. Needs specialist or dealer diagnostics.
63 Controller failure. EEPROM write denied. Needs specialist or dealer diagnostics.
64 Flexible fuel sensor. Flexible fuel (methanol) sensor indicates concentration sensor input more/less than acceptable voltage
65 Manifold tune value. Manifold tune valve solenoid circuit open or shorted
66 TCM to PCM failure. No message from the Transmission Control Module (TCM) to the Powertrain Control Module (PCM)
72 Catalytic converter circuit. Needs specialist or dealer diagnostics.
76 Fuel pump bypass relay circuit. Needs specialist or dealer diagnostics.
77 Cruise control system. Check power to cruise control solenoids.
Enjoy!
You like jazz, she likes Klingon opera, so you compromise - you listen to Klingon opera...
You like Cherokees, she likes Grand Cherokees, so you compromise - you buy a Grand Cherokee...
Old 04-26-2007, 02:24 AM
citizen@large's Avatar
citizen@large citizen@large is offline
Re: Computer Codes For 91-97 XJ
Nice!
Old 04-27-2007, 09:04 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Cool Re: Computer Codes For 91-97 XJ
This deserves a sticky..
Old 05-10-2007, 12:00 AM
A sticky what...?
Old 05-10-2007, 09:15 PM
AlohaBra's Avatar
Well...I sticked it...that is Internet talk on forums....for putting it up at the top for other peeps to look at.
It is considered important information and is in no way derogatory...
Old 05-11-2007, 02:24 AM
A stickey BUN(s) Oh, yeah!
Isn't Idaho a deep state? mmm...
Still, by no means derogatory. I just couldn't help myself.
Wow, I've got game.
~Good Luck, Cause I Luv Ya!
ps~ this comment in this thread in no way attemtps to take away from the validity of said subject matter(s).
