Old 04-24-2007, 10:11 PM
Stealth_3000GT-R Stealth_3000GT-R is offline
2nd Gen. Headlamp question
I was looking on a site that tells you how to clean the clear covers of the 2nd Gen headlamps, and i remember seeing a GTO, that looked like they had removed the clear top cover, has anyone else done this and left them off? i think it looks pretty cool with out the clear cover, but i know the clear cover is to protect the lights n everything, or do you guys think that was custom work done or what? if i find the link ill post it.
Old 04-24-2007, 10:29 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: 2nd Gen. Headlamp question
the lights are still protected. they open up the plastic housing and remove a black piece of plastic hiding the projectors. when re-assembled, you will be able to see the projectors through the clear plastic cover.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 04-24-2007, 10:48 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Up close it looks like crap with the cover removed. Now if you want to remove the insert and "robo" the headlights thats another story.
Old 04-24-2007, 10:53 PM
Linebckr49's Avatar
what would look better is if you took apart the projectors and painted the silver rear housing black.
93 3000GT base
Old 04-25-2007, 11:18 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
This all depends on what year car you have. 94 have a glass cover over the painted plastic, 95+ are painted on the inside of the lexan cover and have no plastic cover thing over the projectors on the inside.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 04-25-2007, 07:23 PM
Stealthee's Avatar
Thats incorrect. I have taken apart two lexan sets and both had the plastic cover.
Old 04-26-2007, 08:05 AM
Good to know, thanks
