| Exterior | Wheels | Tires This is the place for all exterior modifications including wheels and tires. |
new rims!
i just got new rims. they are 18 inch. i was just wondering with the different size rim up from a 16 do i need to adjust the timing or anything else special.
>> 98 camaro rs ... 3.8l v6 .... ill post some pics soon .... |
Re: new rims!
Depends what size tires you got with them. If you didn't match the diameter of tyour old setup with the new setup, your speedo will be off and you will need to adjust the PCM for that.
And what does timing have to do with wheels and tires? |
Re: new rims!
he doesnt know, thats why he was asking. its not necessary to adjust anything except maybe the speed sensor if, like he said, the overall diameter of the wheel and tire is larger or smaller than the original. even if it is larger/smaller, its still not necessary to adjust, just know that you will be going a little faster than what the speedo says if the wheels are larger, slower if they are smaller.
90 Camaro RS V6 - swapped to V8 -350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft ESTIMATED 360-420 hp 380-430lb/ft torque
Re: new rims!
yeah when i went from 16's to 18's i adjusted the speedo doing a pcm tune...real simple
![]() Quote:
Re: new rims!
its a 98, it's a 2 second correction with any type of tuner
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later. 194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies 179.75 RWHP, 204.52 RWTQ ON ITS WAY: MORE R.I.P. Andy 87 Benz 190e - DD 01 EX250 - still gotta get my license for this thing |
