Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 04-24-2007, 07:43 PM
jimmybirds jimmybirds is offline
1990 325i Conv. Help
Looking at buying this car has only 66,000 owner is second and has had it for ten years. tells me it has possible alignment problem in the front. any other issues I should look at??? Thanks
Jim
Old 04-26-2007, 12:37 PM
getfast37 getfast37 is offline
Send a message via AIM to getfast37 Send a message via Yahoo to getfast37
Re: 1990 325i Conv. Help
Low mileage garage queen E30's usually run worse and break more IMHO.
Check the timing belt, water pump, thermostat, belts, hoses, front lower balljoints, front lower control arm bushings, tie rods, sway bar links & bushings, front struts and mounts, rear shocks and mounts, front hubs, rear bearings, exhaust hangers, brake calipers, brake master cylinder, clutch hydraulics, engine mounts, transmission mounts, diff mount, driveshaft flex disc, and driveshaft support. Airflow meter & idle control valve will probably need a good cleaning and the oxygen sensor will probably need to be replaced. Cap/rotor/wires may be cracking by now.
All are wear items on that car, and will go bad from sitting just as much as from driving (if not more so.)
Good luck,
Jon
'98 BMW M3 Sedan #?? TTD & NASA-X D
NASA Mid-Atlantic TT Director, AutoX Coordinator, HPDE Instructor, etc
