Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-24-2007, 05:57 PM
Stealth_3000GT-R Stealth_3000GT-R is offline
Installing a Tach on my Stealth
OK, i have googled the shit out of this, asked ppl, n everything, but i cant seem to find how the hell to install a Tach on my 95 Stealth, this one guy said the off-white wire out of the bottom of the coil pack, and it goes to the ECU, but i was wonderin if there was sum1 who can give me a link to a site or tell me step by step wut to do cuz i dont wanna go pay sum1 to do sum shit i cud do in a hour or few for free, thanx.
Old 04-24-2007, 06:20 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: Installing a Tach on my Stealth
Your best bet is to throw it away...
sorry.. just my opinion..
Welcome to the forums
Old 04-24-2007, 09:07 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
why do you want to install a tach? what's wrong with the stock tach?
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 04-24-2007, 09:34 PM
i dunno why, i just like the aftermarket tachs and plus i put a grant steering wheel on my 3S and it gets in the way of the Tach and Speedo and i put my after market one on the pannel by the window and i can see it better than the stock. and i like the way they look lol.
Old 04-24-2007, 10:28 PM
Linebckr49's Avatar
you DO know you can adjust the height of the steering column, right?
93 3000GT base
Old 04-24-2007, 11:52 PM
yea its at the top now, the wheels is smaller in diameter so the top dont quite clear my view lol
Old 04-25-2007, 01:31 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Shouldn't you be driving a Civic?
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 04-25-2007, 01:33 AM
jason_bet's Avatar
you could probably change all your thread names so far to "how to geto/rice out my stealth"... and have them all under that one topic.. I have a few stickers you can have if you want? one that says NOZ.. its the knock off of NOS but when you fly by.. people think it says NOS
Old 04-25-2007, 07:34 AM
Hotshot8792 Hotshot8792 is offline
I personally don't like aftermarket tach's, but thats just my opinion.
However, if you want to put it on your car, there are two ways to do it. You can either splice your rpm wire into your power transistor unit located by the coil pack near the front center of your engine bay (where all the spark plug wires go to). The ignition PTU has some writing on it by the pinouts, you'll want to splice where it says "tacho". See http://www.stealth316.com/2-pwrtransunit.htm for all the information you'll want to know about the PTU.
The second way to do it is if you don't want to run a wire through your firewall, to tap in by your ECU. Now you have a 95, which could either contain a fed-spec ECU or a cali-spec ECU. The fed spec has 3 harness connectors and the cali-spec has 4. Here is how to access the ECU http://www.stealth316.com/2-ecmremoval.htm. If you have a fed-spec, you will want to tap into the wire coming out of pin 101. If you have a cali-spec you will want tap into pin 58. See here http://www.stealth316.com/2-ecu94.htm for locating your pin numbers.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 04-25-2007, 10:10 AM
im not a damn ricer, i just want to put a tach on my stealth, i dont see whats so "ricer" about it, when gay ass mustangs n shit have them??
Old 04-25-2007, 11:08 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
"Gay ass mustangs" do it because they actually make some real power and use the shift light that is attached to the tach. Their tach also doesn't go up as high as ours does. So if they do a motor swap for something that revs higher their stock tach is useless. That or they are rice, or corn, as well.
Ricer: Someone that adds things to their car to make them look fast, without ever making the car any faster. For example, 3000GT-R
You are a ricer
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 04-25-2007, 11:55 AM
im a ricer because my fav. car is a Skyline GT-R?? so i just put that in my name on here for a NAME, so im a ricer because i like the 3S's and Skylines??? ok wtf ever dude.
Old 04-25-2007, 12:03 PM
I take it "corn" is american cars that look fast??? and i plan on adding things to my car to make it fast, im just gettin the small shit out of the way first, plus my engine is burning oil anyways, im saving up for a twin turbo engine, but im just a little low on money to go out n drop a new engine in my car right now, but i WILL be adding things and doing things to it to make it faster though.
Old 04-25-2007, 12:26 PM
No, because you added -R after a car name that never came in an "R" version, which is something only ricers do. Adding type-R also seems to be popular. If your name was skyline GT-R it would be fine.
Good to hear you will be doing some performance stuff to your car.
Old 04-25-2007, 01:36 PM
jason_bet's Avatar
So let me get this strate... you dont know how to install a tac... and you think you are going to do a turbo conversion??? or are you going to save up and pay someone else to do the conversion?
Closed Thread
