Old 04-24-2007, 10:52 AM
islero666 islero666 is offline
decanted TS paints
Recently I encountered the following problem:
I decanted a TS-49 can for airbrush use and left it in an air tight container for about a month. When I used it, it still had a very good consistency and I continued to airbrush it, first two very light coats and then, when I applied the first wet coat, for a few seconds it looked perfect but then "fish eyes" (tiny circular depressions or spots) started appearing.
The funny thing is that that same day I decanted another can, TS-29 and used it right away and the result was flawless.
My question is: If you decant it, do you have to use it the same day or the pain is ruined or can you use it after some time but have to thin it down again. If so, what kind of thinner would you recommned, I feel that Tamiya's enamel thinner is a bit oily for lacquers.
Thank you all in advance for your expert's advise on this matter.
islero666
Old 04-24-2007, 11:03 AM
Cold_Fire Cold_Fire is offline
Vendor
Re: decanted TS paints
Tamiya has his own Lacquer thinner, it's the same bottle than the acrylic thinner but the cap is yellow. That's the best option to thin the TS paint.
For the "fish eyes" thing I would say that there were some kind of residues on the bottle.
Old 04-24-2007, 11:19 AM
cyberkid's Avatar
cyberkid cyberkid is offline
I have some odd colors decanted into Tamiya jars from summer last year everything seems fine. Here's what I do with older colors. I let them gas out for about 10-15 minutes after I opened the pot and mixed. Before loading my AB I drop a few droplets of Tamiya Lacquer thinner into my AB and spray that...kinda like wetting your throat before swallowing tablets.
HTH,
Steve
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
Old 04-24-2007, 11:26 AM
I guess I will have to be more carefull about how clean my bottles for decanting are. So, this also means that the time between decanting and use has nothing to do with it and they can be stored for a while without affecting the quality of the finish?
Thanks again, Cold
islero666
Old 04-24-2007, 11:33 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
I don't know if this is your problem, but I have noticed that TS-49 is the most likely of all the TS paints I've used (I have a lot) to get the dreaded propellant spotting.
And it can retain a significant amount of propellant in a sealed decanted jar for quite some time.
I back bubble it though my airbrush prior to spraying, that seems to help vacate the gas before airbrushing it... - Mark
Old 04-24-2007, 11:50 AM
Thank you all for your responses, all very helpful and will have them in mind next time I use decanted paints, because despite these problems I feel the results and paint economy when airbrushing is well worth the trouble.
Happy modelling.
islero666
Old 04-24-2007, 07:23 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
What's that?
Old 04-24-2007, 08:13 PM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
You hold your finger over the tip (Covered with a glove or rag or something) and spray lightly. This forces air back into the paint cup, making it bubble slightly. I have seen guys use this technique for keeping their paint mixed.
Old 04-25-2007, 01:10 AM
bvia's Avatar
bvia bvia is offline
By far the best thinner I have found for decanted Tamiya synthetic acrylic lacquers has been Mr. Color Leveling Thinner. As to your fish-eyeing issue I'm betting it has to do with an unclean storage jar OR residual chemicals on the surface to be painted. I've stored decanted TS paints for months without any problems other than the paint thickening (due to evaporative loss of the carrier) and that is easly fixed by adjusting the ratio with thinner.
hth,
Bill
Bill
"Why yes, that IS my bare, carbon fiber Enzo in Scale Motorsport's "How to Carbon Fiber Decaling video!"
Old 04-25-2007, 08:30 AM
cyberkid's Avatar
Originally Posted by willimo
What's that?
Its sometimes known as backwashing. Most commonly used in 2 situations:
1. While cleaning the airbrush. (I backwashed a chunk of dried primer about the size of half a peice of rice the first time I tried the method... around 1mm square )
2. Mixing paint in the jar, or keeping the paint mixed well. IE: metalic paint (alclad, any paint with metalic flakes)
Old 04-25-2007, 09:38 AM
Backwashing is something I do before sharing my beer...
Old 04-25-2007, 09:50 AM
ZoomZoomMX-5's Avatar
TMI
The proper term for the technique being discussed is "backflushing".
I also backflush to stir the paint up a bit while spraying (as pearl and metallic particles settle out), and also in the process of cleaning the airbrush with thinner before taking it apart.
My Fotki Album
Old 04-25-2007, 11:39 AM
tonioseven's Avatar
See, that's the problem right there: sharing your beer!
Old 04-25-2007, 12:01 PM
Eric Cole's Avatar
Eric Cole Eric Cole is offline
I agree, I'll share my paint, my tools... heck I'll even share my plastic with good friends, but my beer...
Eric Cole
Other Model Pictures Here:
http://s5.photobucket.com/albums/y197/justdande/
