Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-24-2007, 06:52 AM
fanworks fanworks is offline
Hmmm, I'm stumped
Well, here's a challenge for ya engine folks. This problem has been persisting since I bought the truck and other than being annoying when at a redlight, and probably degrading my fuel economy, the trucks worked just fine.
Here's my stumper.
When the engine is running, truck is IN GEAR, and the brake pedal is depressed, the engine tends to idle rough. When you let off the brake pedal, the roughness of idle vanishes.
As best as I can trace it, it appears to be vacuum related, but, here's the stumper, I can't find a vacuum leak. The intake manifold is air tight, and after going through 3 cans of starter fluid, I haven't been able to find it in the engine compartment.
So, where should I look, or is this another problem, like some vacuum controled dodad sticking?
I'm stumped, and not certain where to look.
In case yer wondering
Truck
1992 Dodge W-250, 5.9L TBI engine. 4x4, automatic.
CB Channel 17
Space Ghost
'1992 Dodge W-250 Club Cab Long Bed V8 5.9l 4spd H.D Auto 4x4 4.10 Gears
'1974 KIT 11' Kamper
'1987 Custom Built Pullman Mini Camper (The Pullman Mini Camper Project)
'2004 Bi-Mart 1000lbs Cargo Trailer (Chuck wagon)
Old 04-24-2007, 01:43 PM
jrsick jrsick is offline
Re: Hmmm, I'm stumped
Check your tranny fluid level, if it's low then that could be the cause.
Old 04-24-2007, 02:28 PM
here's one other bit to the puzzle that I forgot to mention. In gear, or not in gear, brakes on or not, the TBI has a tendancy to up the engine's rpm for a couple seconds every few minutes like by 200-300.
CB Channel 17
Space Ghost
Old 04-24-2007, 04:40 PM
dcx96 dcx96 is offline
TPS or cylinder misfire.
Old 04-27-2007, 11:09 AM
dethbird dethbird is offline
your trannie fluid is low or the trannie its self may be going out because it is happening to my 1988 Dodge Ram Custom even though it's old as me
john hargrove
Old 04-27-2007, 04:18 PM
Actually, it seems to be related to the map sensor. Upon forcing the truck to go to preprogrammed defaults by unhooking it, the rough idle vanished. The difference between being in gear vs in park is that the engine is under load.
I'll be checking this by temporarily hooking up a new map sensor today, I definitely suspect it as the culprit because after unhooking it for a while and running the truck, then reconnecting it, the engine already saw an improvement.
CB Channel 17
Space Ghost
Old 05-04-2007, 10:41 PM
xj31 xj31 is offline
Ok ,let me see if I got this.It idles rough when you step on the brakes.And you think it might be a vacuum leak.And there is probably a big vacuum hose going to the brake booster.You don't happen to hear any loud hissing noise from under the dash when you step on the brakes,do you?
Old 05-06-2007, 06:01 AM
Nope, no hissing, wasn't a vacuum leak either, it was a map sensor sending faulting data and mixing things wrong.
CB Channel 17
Space Ghost
