Old 04-24-2007, 06:05 AM
darryls darryls is offline
power door locks
Hi, I blew the power door locks hocking up my car amp with the power antenna in the truck, crossed the wires. Now I can't find the fuse for the power locks.
Even phoned the dealer and after him looking in a book he said to look in the engine compartment, it was not a fuse up there or down by my foot .
Any one know were power door lock fuse is for a 93 lesabre
Old 04-24-2007, 06:16 AM
Re: power door locks
okay after reading the through the forums I found that there is a fuse box on the passenger side. guess it is behind the glove box , any one know how to remove the glove box to get to the fuse box?
Old 04-24-2007, 10:58 AM
Luke. Luke. is offline
Fm Darryl S
I could be wrong, but, I believe that you find the fuse box located on the firewall to the right of where the passenger's right foot sits.
In removing/lowering the glove box, I found that removing the three or four phillips screws holding up the front of the box, was all that was necessary.
1997 Buick LeSabre Limited, with Grand Touring Suspension (72,925 miles) with UIM/EGR Stovepipe leakage issues resolved/repaired
& 1995 Saturn SL2 (498,125 miles) as of 6/19/07
Old 04-25-2007, 12:25 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
The fuse you're looking for is on the passenger side, above the black sound insulator under the dash (It's got the courtesy light attached to it) Remove it and you'll see a label attached to the underside of it with the power locks fuse on there. Several other fuses and relays are down there as well. The glovebox does not need to be removed to get to the power lock fuse. Good luck
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 04-26-2007, 01:14 PM
Thank you very much Loekee75, Luke.
