Old 04-23-2007, 10:05 PM
GirlBear's Avatar
GirlBear GirlBear is offline
1996 ls wont start
it started almost stalling at 1st. I could push the pedal down slightly, about an inch. And I would slowly go. If i woul push the pedal any further it would sputter and pop and eventually stall. Now after new plugs and wires no start.
Any one got a clue?
http://jowulf.deviantart.com/
Old 04-23-2007, 11:09 PM
drdd's Avatar
drdd drdd is offline
Re: 1996 ls wont start
fuel filter? nahh ... GirlBear knows better ...
Throttle Position Sensor ?
cleaned the throttle-body lately?
got any fuel pressure at the schraeder valve?
Any one got a clue?
Old 04-23-2007, 11:19 PM
GirlBear's Avatar
I didnt wanna even type the Words "Fuel Pump". But there is no whirl sound when I turn the key. How do I check the pressure. And is there a fuel pump fuse?
Old 04-24-2007, 09:33 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Yes there is a fuse and also a relay and maybe a test port for a pressure gauge and a test wire for power to fuel pump.
Find relay or test wire or gray going to fuel pump and check for 12 volts to fuel pump.
It should have 12 volts key on for 30 second prime up.
But first you have to have good spark to plugs and ing. for the fuel pump to kick in.
Have you got good spark to 2 or more spark plugs.
Any check engine light on?
MT
Old 04-24-2007, 10:12 AM
vtmecheng vtmecheng is offline
If your pump isn't coming on for the 30 sec when you turn the key to "on" check the fuse and relay, a haynes manual will tell you where they are if you have one. If they check out its your fuel pump. I would guess its the fuel pump because it didn't just die all at once but faded out quickly, mine did the same thing 5 years ago.
Old 04-24-2007, 05:09 PM
GirlBear's Avatar
ok, so a friend and i spent all day checking wires plugs cap rotor(all new now). The haynes book said if The oil pressure is low it has a shut off SWITCH to the fuel pump. Well just b4 the blazer died the oil pressure went to zero. It kinda bounced back and forth from 40-0 but stayed at 0 for awhile. but anyway we diconnected the Neg terminal. and now the Shaeder vavle is pressurized. Tried to start, Nothing.! So at this point We have Spark and gas but it seems as tho gas isn't always getting into the thottle body. i stuck my fingers in passed the butterfly and after trying to start it had gas in it. But now it doesnt. So could the injectors be clogged? Im just graspin 4 anything at this point.
Old 04-24-2007, 05:50 PM
MT-2500's Avatar
AF - Advisor
Girl Bear pitch that Haynes book in the trash can on the oil pressure shut off switch.
The oil pressure switch is only a safety switch to keep the fuel pump running if the fuel pump relay quits.
It does not turn off the fuel pump.
If the injectors are squirting you have some fuel pressure and injector pulse.
Can you hear fuel pump run for 30 seconds when key is first turned on or when you are cranking engine?
Do you have good hot blue spark to two or more spark plugs.
And make sure the dist rotor is turning.
Also you need to get a fuel pressure gauge and check your fuel pressure.
If TBI injecction you should have 9-13 lbs of fuel pressure.
MT
Old 04-24-2007, 06:17 PM
JIMMY92w's Avatar
JIMMY92w JIMMY92w is offline
30 seconds for prime! And I thought it was 3
Old 04-24-2007, 06:32 PM
MT-2500's Avatar
AF - Advisor
Maybe if you have a Haynes manual.
MT
Old 04-24-2007, 06:34 PM
blazee's Avatar
blazee blazee is offline
Problem?
These vehicles actually have a 2 second prime cycle.
Old 04-24-2007, 11:23 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
This is a CSFI engine, not a TBI. You need to make sure you have the proper fuel pressure, and good spark. Are you sure you have good constant spark? If you have an ignition problem, your injecotors will not fire properly and its a cascading effect from there. You mention you have good spark, so assuming you do, you have to check your fuel pressure. Keep it simple and you'll get it.
Old 04-25-2007, 02:04 PM
The first question that should be answered is if the fuel pump runs for the 2 or 3 or whatever it is seconds when the key is turned to "on" after being in the off position for some time. I don't know what the exact time is, I always wait like 30 sec or 1 min to be safe (I am sure someone here can tell you the exact time).
Old 04-25-2007, 02:28 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Sounds exactly the same as when the fuel pump went in my 98. Good luck
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 04-25-2007, 03:19 PM
GirlBear's Avatar
Ok its def the pump. And we've decided to cut a hole in the top thru the floor. Cause im not even tryin to "F" with jackin it up and empty'n the tank and messing with all that gas. Also the gas lines and wires sound soooo intimadating. Does any one know where i can get a pic of the top of the actual tank. Just so i can map out where to cut. Thinkin about cut'n to the opposite side of the fuel lines. then bending the piece backwards away from the tank.
Old 04-25-2007, 03:37 PM
MT-2500's Avatar
AF - Advisor
Blazee has it right with 2 seconds time for the blazer 4.3 V6.
I always say a 30 second prime up which is not correct.
Some makes and models may be a little longer and some Times they do not always all the time prime on first key on. Some times you may bump starter to get prime and hit the key on again.
But the prime time is not important it is the prime up when key is first turned on that is.
If you do not have prime up something is not working right.
Do not leave home with the prime up working.
Way back in ford big truck days in the 1960 years they a fuel pump that ran off of the oil pressure switch.
Yes a true no oil pressure kill the engine fuel pump switch setup.
To get them started they had a primer button that had to be push it before they would start.
MT
