Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 04-23-2007, 07:38 PM
MTrachy MTrachy is offline
96 Aurora AC Compressor Removal
I have started to remove my AC Compressor since it is bad need of replacement (noisy grinding noise - no cold air - etc.) I have printed off the steps of how to replace it from the 'Many How To's' article. However, can someone give me a suggestion on how to remove the bolt that is holding the AC lines on to the compressor at the back? I can't seem to get my socket in there. Also, I have seen some references to it being difficult to get the bolt off at the back, what is the best way to get that one out. Any other suggestions on the whole job is also appreciated. Thanks. MT
Old 04-27-2007, 01:08 PM
brcidd's Avatar
brcidd brcidd is offline
Re: 96 Aurora AC Compressor Removal
I remove the 3 front head mounting bolts and the one in the bracket on the rear that goes into the engine block- then slip the compressor and line assembly forward about an inch- then unbolt the line set from the compressor- removing the oil filter helps a great deal as well....I've done about a dozen of these.....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 05-23-2007, 12:07 PM
Thanks. That made it a lot easier. My AC is now blowing good cold air. MT
Old 06-02-2007, 03:13 PM
billysandra billysandra is offline
Yes, I was wondering where you got the instructions on how to remove the ac compressor on an Aurora
Old 06-04-2007, 08:24 AM
I used the step by step instruction that were posted here. You can follow the link below and it will take you to a 'How To' post. MT
http://www.automotiveforums.com/vbul...ght=compressor
