Old 04-23-2007, 03:30 PM
part time mech part time mech is offline
98 exp elec.motor or bad bearing sound
Hi I'm bill and I have 98 6 cyl. 4wd w/ 252k miles While driveing I get his sound from the engine compartment like a motor or something has a bad bearing when I take my foot off the gas When I push the gas again it stops Or when I com to a complete stop it stops Has anyone had this problem ??
Old 04-24-2007, 01:09 AM
TheProphet TheProphet is offline
Re: 98 exp elec.motor or bad bearing sound
In my experience, when bearings begin to fail, it is perfectly normal for them to only make their whine/howl at a certain rpm range. It is MORE common for the problem to occur at low rpm and stop at high rpm, but it happens in reverse at times as well.
I would imagine you're right -- you simply have a bearing that is beginning to go out. Replace it before it siezes.
Old 04-24-2007, 05:14 PM
UncleBob UncleBob is offline
AF -Advisor
could be from the front dif
First thing you need to do is isolate it.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
