Old 04-23-2007, 02:02 PM
pola0042 pola0042 is offline
Bravada 02 Power Window Problem
My driver's side power window will not go up. All of the other windows work properly. The window will go down, but not up. Do I need a window motor or a module switch controller. I was told I need part #15101656, but all of the other windows work. HELP please! Thanks,
Stephanie
Old 04-23-2007, 06:25 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Bravada 02 Power Window Problem
Welcome to AF Stephanie
Pull master switch and with a 12 volt test light or a volt/ohm meter see if it is switching power and ground on the two wires going to the window motor.
Remember the switch switches from ground to power and power to ground to reverse motor direction.
MT
MT
