Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-23-2007, 01:57 PM
steviek's Avatar
steviek steviek is offline
|Where did you run the re-wire wires :)
Hey guys I just got a rewire kit for my walbro 190 and I was just wondering where you guys who have done this swap ran the wires through the firewall, just seeing if you used an existing hole or made your own. I am thinking somewhere on the passenger side near the floor but I dunno if you guys know anything better.
thanks for the advice
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 04-23-2007, 02:45 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: |Where did you run the re-wire wires :)
I like pictures.
http://www.raktron.com/fuel/rewire1.html
Page #2
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 04-23-2007, 09:23 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
When i did mine i just ran it through an existing hole in the firewall.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 04-24-2007, 04:08 PM
steviek's Avatar
thanks for that link i hope the gst isn't too different from awd
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 04-27-2007, 05:05 PM
steviek's Avatar
Hey guys I got a quick question:
when I was doing the fuel pump rewire today the instuctions that came with it and the instructions on vfaq were a little different.
On the one that came with it it says wire the main power supply from battery to terminal 30 on the relay and the vfaq says that wire goes to 87 and vice versa. So whats the deal are they interchangeable or which one is right?
theres vfaw http://www.raktron.com/fuel/rewire5.html
and this is what my instructions say
Connect the push on tabs to the 30A relay terminals as follows:
Main F.p wire (from battery) to 30 (contact). Blue wire from white F.P conntor to 87 (contact). Blue wire from harness to 86 (coil positive). Black wire to 85 (coil ground)
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 04-27-2007, 08:03 PM
I did this about a month ago, heres the thread i started http://www.automotiveforums.com/vbul...el+pump+rewire a made a little diagram the way that i did it at the end of the page and it has worked for me. Hope it helps
94 Talon 1.8L-SOLD
Old 04-28-2007, 12:01 AM
steviek's Avatar
How did you measure 13.8 volts?
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 04-28-2007, 11:07 AM
Honestly i dont remember the exact wire i checked. Maybe either the blue or blue w/black and hooked it to the volt meter. I think i just checked wires going to the pump until i found one with battery voltage. Just remember not to check the wire that you ran that goes straight to the battery cuz of course it will have whatever your alternators putting out, but im sure you already knew that.
94 Talon 1.8L-SOLD
