94 Gc Laredo Losing Power
Hi I have a 94 GC Laredo 4.0. I've been having problems with it. Hopefully someone could give me an idea of what's causing it.
First it sometimes takes a while to start. It will crank and after a few secs it will start up and will shake for a bit and then drive fine. I thought it might be the fuel filter so i replaced it. Did ok for a few days now its doing it again. Now yesterday I was driving on the freeway and I lost power. It started to shake alot . I had the gas pedal to the floor and nothing. I pulled over waited a couple of minutes started right up??? Today it's been shaking like crazy ,sputtering no power.. any ideas would be appreciated. |
Re: 94 Gc Laredo Losing Power
Sean |
could be alot of things like a cylinder misfire or multiple misfire theres a TSB on that try a plug replacement all of them and see. do you get codes? could be CPS the converter I think maybe not.
Finally got a chance to check it out. The rotor was fried.. any ideas on what would cause this? So I replaced rotor, cap, plugs and wires. Now running better than ever. I've only had this vehicle for a little over a month, but by the looks of the old plugs it's been awhile since they were replaced.
Thanks alot for your help
Thats just it; on these vehicles the rotor and cap of the distributor are a wear item, just like plugs and wires. They can and do wear out and have to be replaced.
1994 Grand Cherokee Laredo -- 164,xxx mi -- My workhorse. It starts when nothing else will! ![]() == 1996 Saturn SL2 174,xxx mi -- My little E85 experiment! |
