| Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here. |
trans. swap
I got a 1984 firebird. it has a 700r4 in it now but I want to put in a th350. is there anything I am going to need to change? I have the torque arm bracket but is the driveshaft going to need to be cut or do I need a longer shaft? please help!!
Re: trans. swap
Why do you want to put a TH350 in it??
Re: trans. swap
The belhousings are going to be totally different. The th350 is designed to bolt up to a 90* motor (your 2.8 is a 60* motor).
And welcome to the forums!
- Jason 1995 Pontiac Firebird ![]() ![]() User Guidelines | VB Codes Explained | AF Merchandise "Each of us, is in the scheme of things, insignificant. But millions of insignificant people, doing a tiny bit, can add up to be a very significant force." |
Re: trans. swap
first off, the th350 is a stronger tranny. and who the h3ll said it has a v-6 in it. the car has a 305 that is built as much as one can be. thats why I want the stronger tranny.
first off, the th350 is a stronger tranny. and who the h3ll |
Re: trans. swap
Ah, brain fart.. Sorry about that. I just saw 700r4, and for some reason thought of the 2.8.
Re: trans. swap
Re: trans. swap
yo morley. sorry to thread-jack but damn, your car sounds mean.. whats in her?
Car: ![]() 1997 M6 SS Camaro [ white ] 285's in the back all else = STOCK.
Re: trans. swap
what came on most 2.8 is the 200r4. without the overdrive I am actually making the car have more take off. the trasn crossmember and mount will be OK, but I just ain't to sure about the drive shaft. your IROC sounds sweet. I have an older 305 that is punched .060 over, has clean burn heads, rough idle lunati cam, headers, intake and carb. it is pushing about 300 hp. is there anyone out there who has done this swap?
Re: trans. swap
700r4 > thm350
He thought you had a v-6 because you said firebird, not T/A. Most people with a v-8 know to say "trans am". With the OD feature, you can gear the axle to have more off the line. With a 350 trans (3rd = 1.0) your looking at way less top speed if you are gearing it for a launch, compared to the 700r4 (4th = 0.7 "ish"). GM made so many different variations of BOTH of these transmissions, saying one is stronger or better than the other is subject to each ones intended application. Would you rather have a 700r4 out of a corvette, or a TH350 out of a pickup truck. Unless you have a 700r4 that came out of a camaro/firebird, dont bother because camaro/firebird trans have a specific case built to support a torque arm mount. What are you going to do with the torque arm, hold it in your hand? |
Re: trans. swap
sorry i cant offer much help with the swap but I also will tell you that I would also recommend you keep the 700R4. It will be much easier to get the 700R4 to handle the power than it is to make a TH350 work (buying/fabbing a new driveshaft, balancing it, getting correct shifter location, crossmember, etc.).
I cant remember the first gear ratio of the th350 but the 700R4 has one of the lowest first gears of any auto tranny (3.06), which is best for off the line speed. you also keep the benefit of overdrive. all you really need to handle ~300-370hp is a transgo shift kit and better servos. if you need more power handling you'll also want to add a line pressure boost valve, kevlar band, and beefier reaction shell. switching to a tranny without overdrive is not going to get you a better take off. it's all in the gearing.
90 Camaro RS V6 - swapped to V8 -350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft ESTIMATED 360-420 hp 380-430lb/ft torque
Re: trans. swap
As stated above the 700R4 just can't be beat for a steep 1st gear, and with the overdrive you can run some pretty steep rear gears too. Might want to register at thirdgen.org (TGO) and ask them. There are lots of people over there that have done TH350 & TH400 swaps. |
Re: trans. swap
hotrod_chevyz, you don't have a clue. the tail shaft on the 700r4 is removable, as long as I have the tail shaft it doesn't matter. as for putting a th350 in it, I have the kit from hurst to hold the torque arm.
Re: trans. swap
Re: trans. swap
i looked it up.... the TH350 has a 2.52 first gear which will definitely keep you slower off the line compared to a 3.06 first gear....
...unless you have a very powerful engine (>450hp), very large rear gears (>4.10), have a very high stall converter (>2800rpm), or very skinny/crappy tires... in which case you might want the th350 first gear instead to keep the engine from overpowering your launches, causing wheelspin. i looked and cant find any info about 700R4 to TH350 swap info for third gens....most people are swapping the other way in different cars (for good reason). at any rate here is some info i found... http://www.oldengine.org/unfaq/leadfoot/th350in.htm by the looks of it, i believe you'll need a different crossmember and torque arm mount.
Re: trans. swap
