Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '83 - '90
Old 04-23-2007, 03:42 AM
CWick86 CWick86 is offline
86 jetta reverse problem and more
my 86 jetta will go into reverse but after about 10 feet or so it pops out into neutral again. Also it is very difficult to distinguish between 1st and reverse because it isn't necessary to push down the shifter to get in reverse. I didn't know weather this could be a linkage or transaxle problem ... chilton let me down in this one or i'm an idiot. I've already checked the little plastic separator at the base of the shifter at it seemed fine. Also two of my power windows will not role down, a rear one will not work from either control.
Old 04-23-2007, 04:15 PM
jammyjim jammyjim is offline
Re: 86 jetta reverse problem and more
You probably have sloppy linkages. Have you tried to hold in reverse? If you can hold it there with out problems, then you have a linkage problem. As for the reverse lockout, those things never work right. Try pulling up on the shifter when you go into first. After time, the lever will settle and won't spring all the way back up.
Old 05-11-2012, 07:18 PM
BrantDavis BrantDavis is offline
JAMMYJIM! i'm having the same problem with my 85 jetta and was about to take a friend's advice and change the clutch before i read this. what if when you hold it in reverse like you said and it jerks and bangs wildly? what could be causing this?
