Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 04-22-2007, 08:16 PM
Hawk312 Hawk312 is offline
98 Escort ZX2 stumbling and hesitating....making noise
I have a `98 Ford Escort ZX2 that is having serious issues. When you first step on the gas, it hesitates badly. Upon acceleration, it stumbles badly, and occasionally "pops" which sounds almost like an intake backfire. The problem has been getting worse, and the "Check Engine" light which would start blinking periodically is now blinking more frequently. The exhaust smells rich to me. I`ve already checked the spark plugs and wires. Fuel filter and air filter have been changed. I have tried different kinds of gas with none of them making a difference either way.
Any ideas what this might be? It seems to get slightly worse after the longer the car is driven. Could this possibly be the timing belt about to fail? Is this easy to check/replace? I know it hasnt been changed for atleast 60,000 miles.
WANTED! 1/12 Corvettes and Camaros.
Newest builds. Click on images to go to the thread:
1/12th `69 Z/28 Camaro and 1/12 `67 Corvettes
Old 04-22-2007, 10:06 PM
20zetechzscort 20zetechzscort is offline
Re: 98 Escort ZX2 stumbling and hesitating....making noise
does it jerk really bad? u said u checked the plugs and wires ...so there getting spark? is the mill light setting a code?
1998 ford zx2:
bomz cold air intake
2 baja 12" subs
250 no name amp
sony head unit
1990 eagle talon:
mods to come
Old 04-22-2007, 10:12 PM
oo and the easiest way i can think of to check the timing belt is to pull off the cover on top of your engine (valve cover) to expose your cam gears. and see how its looking ...the other way is to rip it all down like you were to change it. hope that helps some
1998 ford zx2:
2 baja 12" subs
250 no name amp
sony head unit
1990 eagle talon:
mods to come
Old 04-22-2007, 10:51 PM
Hi,
Thanks for the quick response!! I wouldn`t say it jerks really bad...nothing that would hurt your neck atleast. It feels as if one of the spark plugs is fouled out, if that means anything. Its like the engine is stuttering. The strange thing is, I replaced the spark plugs, and it drove much better for a while, though still stuttering and hesitating a bit.
Old 04-22-2007, 10:53 PM
I am assuming the valve cover isnt too bad to do? Does it involve just loosening the bolts up top, or is it going to be a major ordeal? I did change my valve cover gasket on my 89, and it was cake. Is a timing belt change something that can be done in an afternoon?
Thanks.
Old 04-23-2007, 10:13 AM
Markb873 Markb873 is offline
What's the fuel pressure? It could be overcharging. Also, It possibly could be a bad fuel injector. This just sounds like a fuel system problem to me.
The timing belt won't cause any drive symptoms before it fails unless it slips time. Which would cause symptoms all of a sudden and would not become progressivly worse over time.
Just a thought, If you unplug the cam sensor does it go away?
-Mark
Old 04-23-2007, 12:34 PM
-Mark
Is the cam sensor the sensor right on the top of the valve cover? Is it safe to run this disconnected?
Old 04-23-2007, 07:18 PM
Yes that's the sensor. The PCM has a "failsafe" in case the sensor was to fail, in which it runs only off the crank sensor. It will trip p0340 though when you unplug it.
The ignigtion is basically controlled by the crank sensor. The cam sensor adjusts the ignition timing based on the variable camshaft position. If it's unplugged the engine runs in a "basic" ignition pattern eliminating the variable camshaft and the advanced ignition principles.
This will help to determine if there's a problem in your valve timing, if it runs better then the problem is most likly in the head/or timing. If it still runs poor then start chasing down fuel mananagement, airflow, possibly ignition but I highly doubt it because the coil packs last forever and you replaced the wires and plugs already.
Basically it feels like the car has lost about 20hp when this is done because the VCT goes back to maximum retard just to elimate any potential spark knock, or detonation just in case something actually was wrong with that circuit.
Hope this helps,
-Mark
Old 04-24-2007, 02:25 AM
what mark wrote sounds better than what i was thinking. a buddies dad showed me that if u put a flat head screwdriver on the top of an injector u can feel it "ticking" . all your doing is feeling for the injector to open and close. u might be able to try that.
1998 ford zx2:
2 baja 12" subs
250 no name amp
sony head unit
1990 eagle talon:
mods to come
Old 04-24-2007, 11:46 AM
zefyr zefyr is offline
I had the same problem develop not long after I replaced the timing belt. Later it turned out the belt was off one tooth, and I corrected it and replaced the spark plugs. The problem went away and it drove great - but not for long.
If the problem is the same, I've found that it runs normal while the engine is cold. After it warms up, the misfire starts and I get the blinking MIL. I use the ELM32 OBDII system with my computer, and it doesn't find any recorded codes. Clearly it has to do with the ECM controlling the timing, as the service manual describes the ECM going into closed loop state after the engine is up to temperature.
The suggestion about the crank position sensor is a good one, I plan on taking a closer look at it.
Old 04-24-2007, 07:03 PM
Thanks everyone. It does seem to run just a little but better when it is cold, but not by much. I tried unplugging the sensor, and nothing changed. I removed the cover on top of the timing belt, and it felt like it had plently of tension. There is some very minor cracking along the outside of the belt, but not too much. I also checked the spark plugs, and besides some carbon buildup, they look normal.
So I am guessing the problem is somewhere in the fuel system. Supposedly the fuel filter was changed about 15,000 miles ago. If anyone else has any suggestions, please let me know.
**ALSO......
I just took it out again tonight for another drive. After about 15 minutes of driving, I noticed the catalytic convertor is glowing bright red! There is also a severe exhaust leak right around the firewall where the down pipe connects to the cat-back. Could this be the cause of the problem? Would the car run rich from an exhaust leak? The pipe is almost completely severed.
Old 04-24-2007, 10:56 PM
well if the car had a EGR that could be the problem. but i have a 98 zx also and im almost sure that they dont have one...like mark said maybe the fuel system is over charging and not burning all the gas..ill talk to one of my college teachers and get his input for ya. he has a nack for trouble shooting
-Dan-
1998 ford zx2:
2 baja 12" subs
250 no name amp
sony head unit
1990 eagle talon:
mods to come
Old 04-25-2007, 10:22 AM
Nah there's no EGR on a ZX2 they have the VCT on the Exhaust cam to mimic the functions of an EGR. Also, a bad fuel filter would have the opposite effect.
As for the Exhaust leak. The Ford book I have does include exhaust system checks as a diagnosis of a rich condition. I suppose if it's upstream of the o2 sensors the extra air getting in will cause the sensers to think the engine is running lean so it will add more fuel. Which is supported by the carbon on the plugs. However, on personal experience, I had a "great" car that had one bolt holding on the exhaust manifold on the engine, so a major leak, and it caused no drive symptoms other then noise. However, It only had throttle body fuel injection, or as I called it a "fancy carburator" and OBD-I. So It may not even compair. However, I suppose it makes sense because the PCM doesn't rely on the O2 sensors until the car is warm.
-Mark
Old 04-30-2007, 11:20 PM
mark what woud make the cat glow red? i talked to my teacher and he was not much help.. all he said it that it could be a # of things...
1998 ford zx2:
2 baja 12" subs
250 no name amp
sony head unit
1990 eagle talon:
mods to come
Old 05-01-2007, 10:17 PM
I've never run into that before. I would assume that there's excessive heat in the exhaust. Like maybe the exhaust leak is causing some afterfire and it's burning the rich mixture down through the manifold or perhaps in the catalyst. Like in Nascar when they crash and refire the engine, fire burns out the exhaust because of a puddle of fuel in the header.
I don't think that's the problem just a symptom of the problem exaggerated by the exhaust leak.
-Mark
