Old 04-22-2007, 06:33 PM
HHoover1874 HHoover1874 is offline
Outside mirror on '98 Blazer
I have a 1998 Chevy Blazer and the driver's side mirror was broken off from the door. The plastic portion was completely broken from the door. What would be the best manner to go about repairing it? It appears difficult to remove the door parts to fix it. Please let me know. Thanks.
Old 04-22-2007, 06:51 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Repair mirror of '98 Blazer
Why not ask them over there in the Blazer forum?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-22-2007, 09:00 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Re: Outside mirror on '98 Blazer
It's actually a pretty easy job, just remove the door panel and it's just three bolts and one plug. To remove the door panel you need to remove two or three screws usualy two in the armrest and use a tool like this: http://www.sjdiscounttools.com/vimdt6200.html or a wide screwdriver blade to pop the door panel off, it's just held in place by pop in plastic studs. Drive a blade under the bottom of the panel and slide it back and forth to locate them and pry them off. Don't worry if they snap off when removing the door panel, they're cheap to replace.
The actual mirror replacement instructions are here: http://www.autozone.com/az/cds/en_us...rInfoPages.htm
If there's a slavage yard near you with a "pull your own parts" policy go pull a junker apart first and get the part before you tackle your's, you'll learn a lot and you be better prepared to do it again on your own rig.
Old 04-22-2007, 10:54 PM
Thanks. It seems easier than I thought. I'll let you know how it turns out.
Old 04-22-2007, 10:56 PM
I did not realize that I was still on the Caprice site. I have a Caprice, also, and registered under it. Thanks.
