Old 04-22-2007, 07:02 PM
gw84's Avatar
gw84 gw84 is offline
Send a message via MSN to gw84
car stereo question
I'm looking to buy a used car stereo for my second car. I have one (already installed) that I love and I want to get the same model again, Only problem is that I can't find it new anywhere. I have found it used on ebay, but there's a slight problem. It comes with the unit, faceplate and mounting sleeve. Problem is that the wiring harness is NOT included. Is this item something that I can buy somewhere else or are they different from stereo to stereo and hard to replace? I like the stereo a lot like I said, but I don't think I should buy it if it's going to be a major PITA to get it hooked up.
This ain't your grandma's car!!
Old 04-22-2007, 08:17 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
Re: car stereo question
you can buy them on ebay, along with the used deck.
BTW, there is a car audio forum.
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
Old 04-22-2007, 08:40 PM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
Moved
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 04-22-2007, 08:42 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Which harness are you referring to? There should be one that plugs into the back of the head unit, and then you can buy one that plugs into your existing factory stereo harness so you don't have to chop it off and hook all the wires up. It looks like this:
car factory wires -> harness that plugs into factory unit -> harness that plugs into that harness to expose color-coded wires to connect aftermarket head unit -> wires from aftermarket harness that plugs into head unit
The harness that plugs into the head unit should come with when you buy it. You just need the adapter to connect all the wires up, right? Walmart, radio shack, etc. carries those or you can buy them online or at a local car audio shop.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 04-22-2007, 10:46 PM
gw84's Avatar
Ok ok ok. I now know that there's a Car Audio forum. I thought it fit in the Computer/ELECTRONICS/Technology forum just fine. At least I'm not asking about a Chevette in the FORD forum!! Gosh!
Anyways, I'm not really sure which harness the listing refers to. The listing on ebay simply says that it "does not include the wiring harness." If the bidding doesn't go too high, I'll get it anyway and take my chances, however if it goes high, I'll just pass and not deal with the headache. Thanks for the help
