Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 04-22-2007, 05:33 PM
mikecarter mikecarter is offline
front brake pads
replacing brake pads did rear easy know im at the front pads no screw i saw it said use a c clap i dont have won any inf would be great got the caliper to move so there space between the pad and rotor now but i cant get them out
Old 04-22-2007, 07:21 PM
maxwedge maxwedge is offline
A990 racer
Re: front brake pads
Welcome to AF. Tough to make out your post, spelling issues? Try large channel lock pliers also, or get help from a pro.
Old 04-26-2007, 02:42 PM
kiway22 kiway22 is offline
Send a message via Yahoo to kiway22
I had trouble removing my front pads. seems a rivet on the inside pad would catch on the inside of the caliper. I used a very large c-clamp and about a 4 inch extension. I put the extension across the top of the pads, and inside the caliper piston. Then I was able to use the c-clamp, to push in on top of the extension, which pressed the piston in, enough so I could remove the caliper.
