Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 04-22-2007, 02:20 PM
aukster aukster is offline
Transfer Case
I have jsut recently bought a 99 GCL. everything appearsr to be running fine etc. I went to have the oil changed in it and there rwas no fluid in transfer case. We added fluid to it and a couple of days later I noticed I was having a leak somewhere. Went to have it checked and guy told me there was a crack in the transfer case. Well we tried to drain it real good and clean it real good and put some "JB" weld on it. Well it's still is leaking. How hard is it going to be to take it off to have it welded? Will it hurt it much to run it with out fluid in the transfer case. It has the quad-trac 4wd system. Any suggestions would be helpful. Thanks
Old 04-24-2007, 10:16 PM
msdz msdz is offline
Re: Transfer Case
Taking the transfer case off is no real pain. just remove the driveshafts and then loosen the bolts/nuts(whichever it may be) and just drop it. Maybe 30 minutes if that, depending on how fast you work and if you have the right tools available at the time you start working on it. Recomendation... go to the the junk yard and see if you can get a used one with a warranty. I would not weld the transfer case cause it really does take some abuse and the type of metal most welders can not do a good enough job for it to hold good. So you end up only having a partial fix and you may never know how long it will hold but then again a used one from the junk yard may not be any better, the reason you see if they will warranty it for maybe 3 months.
