Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-22-2007, 12:35 PM
BigDanTheMan's Avatar
BigDanTheMan BigDanTheMan is offline
I read and am helpful.
Send a message via AIM to BigDanTheMan
generic? k&n filter problem
fellows:
i've had this on my car for two years now: http://www.brothersperformance.com/c...roducts_id/810
and i'm in the process of putting on a 65mm tb & egr when i pull this unit and about a mouthful of water comes out. it wasn't raining hard at all last night, but i was on the highway for an hour in the drizzle. the filter looks like a K&N with moroso stamped on the top, but i'm not sure. if it is a legit k&n i'll clean it, but if not i have to wonder if the filter worth cleaning or should i just send for the k&n of the same size? i have enough cleaner and oil to work on this one.
- Dan
free hypsi87!!
Dan's White Horse
Bring back Melt Crew 002 - 3657 posts can't be wrong!
Old 04-22-2007, 12:44 PM
Re: generic? k&n filter problem
follow up question:
if i had to buy another filter should i go with the one that looks and is the exact same size: http://store.knfilters.com/search/pr...x?Prod=RU-4190
or the slightly bigger one that would still fit in the fender wall?
http://store.knfilters.com/search/pr...x?Prod=RC-5040
free hypsi87!!
Dan's White Horse
Old 04-22-2007, 12:57 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Is your fender sealed? When I had my Stang, there was no way water could get into it. If its a moroso, they make pretty good stuff, I would just clean that, and use it till it falls apart.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 04-22-2007, 02:03 PM
its more enclosed than sealed, but i can't imagine enough water getting splashed under the filter to soak it. the newest crisis is that the bolts from the upper intake manifold to the egr are corroded soild and in my effort to pry off the spacer with a pry bar i popped a hole into the valve cover.
i love to learn
free hypsi87!!
Dan's White Horse
Old 04-22-2007, 02:46 PM
SkylineUSA's Avatar
Its more like live and learn
Old 04-22-2007, 04:03 PM
a deeper look
now that i've got the upper manifold off i notice a greasy film that coats the walls of the lower and upper intake tracks. something tells me that there shouldn't be oil up there - can anyone explain this? is that normal for a 20 year old car or maybe has dirt accumulated over the years and now that water may have been passed through the filter it has turned into an oily mud.
free hypsi87!!
Dan's White Horse
Old 04-22-2007, 05:03 PM
351wStang's Avatar
351wStang 351wStang is offline
The upper intake on my truck which has a 5.0 in it was black inside if thats what you are talking about its the pcv recirculating.
1969 Cougar
357w & TKO - 475hp
Old 04-23-2007, 01:17 AM
ah good. that is relaxing.
free hypsi87!!
Dan's White Horse
