Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 04-22-2007, 12:33 PM
hitachi hitachi is offline
Heater Problems
When I change the selector switch from defrost to the floor the air wether it's hot or cold is blowing out the front vents, can someone tell what the problem might be ?
Old 04-22-2007, 07:23 PM
hotbug1776's Avatar
hotbug1776 hotbug1776 is offline
Re: Heater Problems
bad vacuum hose, actuator, or selector switch, or it got disconnected in the engine bay. you need to check the hose in the bay to make sure it's still hooked up. then remove the lower dash and inspect the hoses and actuators.
if everything is hooked up and not leaking, then the selector is not working.
