Old 04-21-2007, 11:59 PM
jjh1976 jjh1976 is offline
92 taurus cel
hey fellas is there an easier way to retreived codes from a 92 taurus one method was to use an analog meter. i only have a digital (fluke 88)
when im driving after a few minutes it will come on for a few minutes then go out. the car dont run funny or any other adverse drivability issues it is more annoying than anything. again thanks this forum rocks
jason
Old 04-22-2007, 02:46 AM
TaurusKing TaurusKing is offline
Re: 92 taurus cel
For like 30 bucks or so, you can get the obdI scanner for your car..
Old 04-22-2007, 09:00 AM
shorod's Avatar
shorod shorod is online now
SHO No Mo
Re: 92 taurus cel
You can use a jumper wire and no meter, then count the flashes on the Check Engine Light. For a list of codes and diagrams on how to connect the jumper wire, see http://autorepair.about.com/cs/troub...l_dtcs_18a.htm. The connections are shown at the bottom of the webpage.
-Rod
Old 04-22-2007, 09:14 AM
Re: 92 taurus cel
That's even better, free.... 30 bucks can go into the gas tank
Old 04-22-2007, 08:55 PM
Re: 92 taurus cel
thats what i was looking for shorod thanks a million.
and thanks taurus king.
so shorod have you completed your engine swap.
im now looking for a sho project. wich engine is the yamaha engine
and again thanks you guys rock
Old 04-22-2007, 08:56 PM
Re: 92 taurus cel
sorry shorod i got you mixed with someone else
Old 04-23-2007, 09:45 PM
shorod's Avatar
SHO No Mo
Re: 92 taurus cel
No problem. I suspect you are thinking of "acidbath." I believe he's recently re-worked his Yamaha V6 SHO engine completely.
-Rod
Old 04-25-2007, 04:23 PM
Re: 92 taurus cel
yes that is exactley who i was thinking of. any ways i scanned it for codes and there were none. will the method you told me about read for stored codes
Old 04-25-2007, 11:02 PM
shorod's Avatar
SHO No Mo
Re: 92 taurus cel
Since you perform the test with the key in the run position, engine off, the only codes it will display are stored codes.
-Rod
Old 04-27-2007, 02:33 AM
Re: 92 taurus cel
well i bought the scan tool and it showed code 63 46 34itested voltage at the tps and there was 5 volts. so im thinking that happened when i unpluged the tps. one of the codes is for the egr valve wich would explain the stalling every now and then. the other code im not sure.
Old 02-28-2008, 06:51 PM
phreaq's Avatar
phreaq phreaq is offline
Re: 92 taurus cel
-Rod
That only shows the set up for the anilog meter test. How do I get it to show them through the engine light?
Old 02-28-2008, 06:56 PM
phreaq's Avatar
Re: 92 taurus cel
Nevermind found in another post
http://www.troublecodes.net/Ford/
Old 02-28-2008, 07:44 PM
shorod's Avatar
SHO No Mo
Re: 92 taurus cel
It shows both methods. The upper diagram with the jumper wire is all you need. With the key off, you install the jumper wire. Once the wire is installed, turn the key to the run position and the CEL will flash out the codes.
The lower diagram showing the analog meter works the same as far as key positions go, but instead of watching the CEL, you count the meter swings.
-Rod
