Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 04-21-2007, 07:05 PM
Bigguns Bigguns is offline
Eighty Eight from hell
I drive a 94' olds eighty eight 3.8 with 110k on it. Recently it died, and wont fire again. It will start randomly, but dies within 10 minutes. Ive replaced the ECM, oil pressure switch, fuel filter, crank shaft position sensor, and am about to change cam shaft position sensor. It stalls with no rhyme or reason, and im about to give up on it. The fuel pressure is at the rail, it has spark, but wont run. Any advice greatly appreciated !!
Old 04-22-2007, 10:10 AM
maxwedge maxwedge is offline
A990 racer
Re: Eighty Eight from hell
Welcome to AF. When it won't start, good spark to all cylinders, do the injectors pulse, so far you have replaced parts with no diagnostics performed. Will it start with carb cleaner sprayed into the intake?
Old 04-22-2007, 04:17 PM
Diagnostic gave codes for camshaft / crankshaft. Didnt think it was camshaft, so as I said I replaced the crank shaft sensor. That didnt work so camshaft is the only thing i can think of next (or maybe ignition switch.) Didnt spray intake because i dont want to damage mass airflow sensor. This is bizarre ive never had a car so stubborn
Old 04-24-2007, 09:45 AM
razr_88 razr_88 is offline
Send a message via Yahoo to razr_88
did you try checking for continuity in the crankshaft wiring?
Old 04-24-2007, 03:07 PM
A990 racer
Question Re: Eighty Eight from hell
Ok you you will continue to replace parts till one fixes it. The advice given directs definitive diagnostic steps, without doing this any advice here is useless! Spark, injector pulse, are they there?
Old 04-24-2007, 08:02 PM
guitarsandcars88 guitarsandcars88 is offline
ICM maybe?
Old 04-26-2007, 04:03 PM
Originally Posted by maxwedge
Ok you you will continue to replace parts till one fixes it. The advice given directs definitive diagnostic steps, without doing this any a dvice here is useless! Spark, injector pulse, are they there?
found broken wire in harness! fixed problem.. thanx for all the help
