Old 04-21-2007, 04:12 PM
blazer797 blazer797 is offline
Wipers On And Off
NEED SOME HELP WIPERS ARE GOING VERY SLOW THEN JUST STOP BY THEMSELVES . I HAVE TO GET OUT IN THE RAIN AND PULL ON THE WIPER ARM FOR THEM TO START GOING AGAIN SOMETIMES IT WORKS SOMETIMES THEY STAY OFF FOR A WHILE THEN RESTART IS THIS THE WIPER MOTOR OR MODULE SENSOR?
Old 04-22-2007, 01:26 AM
DelCoch's Avatar
DelCoch DelCoch is offline
Re: Wipers On And Off
The '95-'96 has a problem with the circuit board going bad, which is attached to the bottom of the wiper motor housing - bad solder joints on the circuit board. This could be your problem, or it could be a problem with the electrical contacts underneath the circuit board.
What year, type vehicle do you have?
Old 04-22-2007, 08:25 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
All GM and GMC trucks from 95 to 98 had a bad Pulse board design.
(As DelCoch mentions, bad solder joints)
More likely than not the problem.
Replacement boards available at most parts stores for ~$35.00.
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 04-22-2007, 09:41 AM
1996 chevy blazer s10 4.3l
Old 04-22-2007, 09:44 AM
mike how do i change the pulse board and do i need to solder it or is it a plug
Old 04-22-2007, 10:05 AM
Blutarski's Avatar
Blutarski Blutarski is offline
You just take out the 4 or 5 torx bolts that hold on the cover, it's right behind the ignition, on the firewall, at the base of the windshield. Take those out, swear when you lose one down inbetween the firewall and engine. Then pull the board out. You can re-solder the power leads if you want. It may last for a while but the 3 bucks isn't bad for the replacement. Just plug it all back in and go for it.
The slow wiper situation sounds like it could be the wiper motor, though. The pulse boards had more of an issue with the wipers not working at all, or when they felt like it.
Lotsa luck
Being Shot out of a cannon will always be better than being squeezed from a tube. That is why god made fast motorcycles, bubba.
-Dr Hunter Stockton Thompson
07 3.6L Passat 4 Motion Wagon - 04 6.0L Silverado 2500HD - 98 4.3L Blazer - 95 Moto Guzzi Sport 1100 - 81 Moto Guzzi CX100
Old 04-22-2007, 07:32 PM
Lotsa luck
I agree with the above.
The bad solder joints are actually at the connector end on the pulse board.
(some of the earlier models had a problem with Capacitors vibrating and craking the solder). I just replaced the board, as I couldn't find any bad solder joints.
Mine has 2 T10 torx bolts holding the cover on (it sits on top of the wiper motor), disconnected the connector at the top of the board, and slide it off the wiper motor housing.
Old 05-28-2007, 08:58 AM
justdon justdon is offline
I wish I had seen this earlier.......
GM has a non expiring recall on this issue. They will replace the board for you, free of charge.
I had mine replaced in 2004 on a 96 s-10.
Old 05-28-2007, 10:30 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Welcome to AF.
You were luckie.
There is a lot of years that is not covered under the recall.
MT
Old 05-28-2007, 11:47 AM
On my '97, The "Special" recall ended at 7 yrs, or 70k miles, whichever came first.
I missed the "special" recall by 1 month.
Old 05-28-2007, 03:17 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
I re-soldered 1 bad and 2 more possibly bad joints on the board on my '97 Bravada and a pal at work's 2000 S10.
