sensors and spark plugs
1997 Ford Expedition have had the same O2 sensor issues others have had with codes for spark plugs. Changed two O2 sensors and seemed to solved issue but the idle and accelaration jerk is back.
Before I attempt to change the plugs I wanted to get the advice and recommendations of those who have attempted this:
It is a 1997 Exp 5.4 Thanks |
Re: sensors and spark plugs
rockauto.com has the coil packs in the range of $41.78 to $55.79 depending on the brand. Never done the job, but for he money, I think you should look it over. good luck. I have ordered parts from them for my windstar, and the experience has been good.
Before you go real far, what are the trouble codes or which cylinder is causing the problem? There is no need changing all the coils if only one is bad. If there are no trouble codes, it may be worth an hours labor at the dealer to find which cylinder is missing then do the work yourself. Simple tools are needed to replace the parts. A 7mm socket to remove the coils and a spark plug socket and ratchet. Just take your time cause some of the plugs are kinda hard to get to.
Being way2old is why I need help from younger minds The sooner you fall behind the more time you'll have to catch up. ![]() HEY Y'ALL--READ THIS Here are some of our old vehicles for sale.
I agree with the ol man! Only replace bad coils. Changing the plugs is time-consuming, but can be done with patience.
