Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-21-2007, 10:31 AM
77CapriceClassic 77CapriceClassic is offline
Shifting from park
When I shift from park to anything else, the red line stays on park. Does anyone know how to get those two things coordinated so when I shift from park to drive for example, the red line will go to drive?
Old 04-21-2007, 12:23 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Shifting from park
Welcome aboard!
If you take the steering column access plate below the column off, you should see where a string connected to a little stainless steel fastener is pushed onto the column. This string is what pulls the indicator in the shift quadrant. Make sure it's connected and that it has tension on it.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-21-2007, 12:47 PM
Thanks! I will give that a try and see what happens!
