Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 04-21-2007, 10:14 AM
r_2016 r_2016 is offline
update on funny sound
It looks like that sound was not coming form under the hood but from it sounds like from the tires.....I had a friend tell me that it could be one of a few things 1, brake sensor 2, bad wheel bearing 3, somthing in the driveshaft. Anyone have aby input on this issue. Thanks (If you guys did no read the other form the problem I am having is a clicking sound that seems to follow the speed of the tires meaning when I drive faster the sound speeds up and when I drive slower the sound slows down, and this is for a 1997 Towncar with 64,000 miles on it) Thanks for your help guys.
Old 04-21-2007, 10:40 AM
Re: update on funny sound
(he told me that the thing on the drive shaft is called a universal joint)
Old 04-23-2007, 07:23 AM
mr wiggl3sv2 mr wiggl3sv2 is offline
Banned
Its not a U-Joint
Sounds like a differential, or a gear broke? but i dont know
If you could describe it better that would help out alot
Old 04-23-2007, 08:38 AM
Rags37 Rags37 is offline
some cars have warning noises when the brake pads are getting low and need changing, could this be a possibility. I had a Buick once that had a squeek, that only sounded when the car was moving, and the faster I went the more rapid the noise was. That did turn out to be the U-joint, change it and the noise went away.
Old 04-30-2007, 12:05 AM
Dmartin_1 Dmartin_1 is offline
Smile Re: update on funny sound
Sounds like a bad Cat. Conv.a makeing the noise
