Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 04-21-2007, 07:43 AM
Divorce Court Dan Divorce Court Dan is offline
Send a message via AIM to Divorce Court Dan
Trans code 58
93 Suburban with 454. Pulled a couple codes. One being the coolant temp sensor which was replaced. The other one is a code 58 "Trans temp Sensor Low". Just wondering what to do about fixing the trans problem. Thanks in advance.
Old 04-21-2007, 01:10 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Trans code 58
Depending on which transmission it is circuit or sensor bad.
To test you have to watch the transmission temp sensor readings on a scanner.
See if it is reading right at all temptures cold and hot and or dropping out or shorted out.
Could be bad wiring or sensor.
If a 4L80 transmission check the transmission wiring plug in for fluid in it.
MT
Old 04-21-2007, 01:39 PM
Re: Trans code 58
Ok. I will check that. I also need to find out what tranny is in it. Thanks
